How much power will a D16a6 head do on a D15b2 block?
Old Jun 14, 2004 | 02:05 PM
DontBaPlayerh8r's Avatar
Default How much power will a D16a6 head do on a D15b2 block?
I wanted to know if any one knows and thing about puting a D16a6 Head onto a D15B2 block. My hatch is an Si so the D15b2 is running the D16a6 ecu, intake manifold etc..,
Old Jun 14, 2004 | 02:15 PM
91civicEX's Avatar
Default Re: How much power will a D16a6 head do on a D15b2 block? (DontBaPlayerh8r)
itll make less power than the d16 but more than the d15. theres not that many numbers in between. why does your si have a d15b2?
Old Jun 14, 2004 | 03:44 PM
dr_latino999's Avatar
Default Re: How much power will a D16a6 head do on a D15b2 block? (91civicLX)
Here is the deal: the D16A6 head and the D15B2 head are exactly the same, the only difference is the camshaft. Also, you may be running MPFI, which if that is the case puts you around 102 hp, the same as the D15B7. If not running MPFI, expect around 96-98hp - ish.
mon.jar94
May 20, 2013 07:42 PM
FaNiO
Oct 20, 2009 09:41 PM
efcivicsi
Feb 20, 2003 09:17 PM
