Motor Vibrating????
I am getting some serious vibrations from 3000 to 6000 RPMs. I just changed my timing belt and balance shaft belts. I am sure that the balance shafts are in the proper position. What else could this be? I used to get some vibration from around 4500-5500 but now its a lot worse. I have ES Motor mount inserts. And I am running a JRSC but even without having my blower hooked up it still shakes. Any suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sooco100pf »</TD></TR><TR><TD CLASS="quote">are you sure they vibrate that much? Mine is really bad and now it's worse than before.</TD></TR></TABLE>
well you could hav etoehr issues, if your really concerned take them out and then ry your car, my friend has inserts all around and his car vibrates pretty bad.
RacerSi
Nov 17, 2003 02:42 PM
