h22a engine code 22
Old Jun 13, 2004 | 10:03 PM
93 accord H22a's Avatar
Default h22a engine code 22
when i drive my car after it warms up the engine light comes on and throws code 22. that is the v-tech pressure switch. i switched the hole assembly and i am still getting the code.
any help would be awsome
Old Jun 14, 2004 | 08:26 AM
staticrex's Avatar
Default Re: h22a engine code 22 (93 accord H22a)
Hey when you replaced the switch how did you get the green connecter off of the old switch?
But the 22 can be associated with alot of things.
Check oil level.
Clean the filters in the vtec solenoid, and the filter between the pressure switch and the block.
Check grounds and all wiring.
Old Jun 14, 2004 | 11:20 AM
Turbogixxer's Avatar
Default Re: h22a engine code 22 (staticrex)
Is it even wired up?
Old Jun 14, 2004 | 12:19 PM
Default Re: h22a engine code 22 (turbogixxer)
yes it is wired up, it worked until we started getting hotter weather.
Old Jun 14, 2004 | 12:23 PM
the green switch came on the new assemble, plug and play.
oil was ok,
the little screen in the switch it self was clean,
it gets very hot under my after i have been driving i was thinking that had something to do with it
Old Jun 14, 2004 | 03:40 PM
staticrex's Avatar
Hey do you have the part number for the switch?
Thanks
I don't think heat would have anything to do with it, as I live in Vegas and 100+ degree days and don't think that was my problem.
Old Jun 14, 2004 | 05:15 PM
The part number is 15810-p13-005
Old Jun 15, 2004 | 08:20 AM
staticrex's Avatar
Thanks man, I appreciate it.
Mike
Old Jun 15, 2004 | 10:30 AM
what's up my car went one whole day without that dam light coming on
Old Jun 15, 2004 | 11:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93 accord H22a &raquo;</TD></TR><TR><TD CLASS="quote">what's up my car went one whole day without that dam light coming on
Loose connection (wires) maybe.
lcommisso
Dec 10, 2018 09:13 AM
UDUBdriver
Engine Management and Tuning
Sep 4, 2011 07:04 AM
hondaswap
14
Jul 21, 2009 09:21 AM
preludefien
Feb 11, 2007 10:43 AM
EK9KiNG
Aug 4, 2006 02:35 PM
