B16 into 91 crx
Old Jun 13, 2004 | 09:00 PM
sbcrx's Avatar
Default B16 into 91 crx HF
I just got a frist gen b16 full swap wit lsd, and umm i was wondering what hooks up with little to no modification, and what axles will i be using, been told maybe 91-93 integra axles. Will my original Hf harness come to use?
Old Jun 13, 2004 | 09:10 PM
Malgerus's Avatar
Default Re: B16 into 91 crx HF (DployinCRX)
Use hf harness, add wiring for VTEC and knock sensor.
SEARCH
Old Jun 13, 2004 | 09:27 PM
shaddr3's Avatar
Default Re: B16 into 91 crx HF (Mr. S)
90-93 teg axels is waht you need
Old Jun 13, 2004 | 10:02 PM
DC 2's Avatar
Default Re: B16 into 91 crx HF (shaddr3)
What axels you run depends on what half shaft you use, here is a link to answer that question.. http://cayotic.com/Axles.html
read up at these links
http://texas.clubsi.com/brandon/crx/frame2.htm
http://b16a.honda-perf.org/theswap.html
http://www.geocities.com/teampimports/b16a.html
http://www.phatwhippincrx.20m.com/custom.html
http://tjshondas.20m.com/b16awire.html
That swap is very common and has been covered many times, try looking in the faq section at the top of this forum, or run a search. select archived function for more results.
Goodluck
Old Jun 13, 2004 | 11:08 PM
EL Vap133's Avatar
search.
ltzracer
Nov 17, 2006 06:09 AM
RACING INTEGRATION
Mar 3, 2006 08:09 PM
1990crxhf
13
Jan 26, 2004 09:12 PM
crix180
Jun 29, 2003 12:55 PM
hybridrexsir
Apr 10, 2003 02:46 PM
