Ignition switch 12 v power source?
Old Jun 13, 2004 | 02:17 PM
BoRiCuA's Avatar
Default Ignition switch 12 v power source?
where would be a good 12v power source from the ignition switch?
Old Jun 13, 2004 | 02:52 PM
91civicDXdude's Avatar
the fuse box. there are three auxiliary plugs and one ofthem is ignition switched. the other two are all time hot and headlight switched.
Old Jun 13, 2004 | 03:44 PM
Full Race A6's Avatar
Default Re: (91civicDXdude)
Ya I always wonderred when accessories said like 12v switched and stuff like that, how do I wire the power wire? Im guesisng I need a voltimeter?
Just for small stuff like my neons for my system, I just ran them right to the battery, dont know how to tap into the fuse box correctly, can anyone explain?
Old Jun 13, 2004 | 04:49 PM
Jester88Si's Avatar
near the fuse box look for a thick White/black wire there should be two they're the main power wires (which means constant not switched)
Old Jun 13, 2004 | 05:09 PM
Default Re: (Jester88Si)
And you can tap wires into this with a female connector?
Old Jun 13, 2004 | 05:15 PM
Jester88Si's Avatar
Default Re: (W O T)
Yeah if its the kind that splices in, since its the main power wire you should fuse whatever you connect to it.
Old Jun 13, 2004 | 05:16 PM
BoRiCuA's Avatar
hmmmm i don't see them? the 2 white/black are always hot so i can't use them which is the other that is switched?
Old Jun 13, 2004 | 05:21 PM
Jester88Si's Avatar
Default Re: (BoRiCuA)
Most of the ones in the fuse box are switched use a test light or voltmeter to find a switched source anywhere from there. There are some constant wires in the fuse box but it makes no sense to get them from there.
TooManyHobbies
Sep 22, 2014 05:12 PM
dwerpk
Jan 16, 2008 01:59 PM
mxl36o
Nov 25, 2006 10:02 AM
RCautoworks
May 18, 2003 05:56 PM
JoshRambo
Jul 20, 2001 03:42 PM
