I give up on b16!!!!
Old Jun 13, 2004 | 12:59 PM
wpgcivic's Avatar
Default I give up on b16!!!!
swap is in my hatch and i get vtec and all but i still cant beat my brothers stock d16a6 in his crx, this is welfare, so i think i am going to sell it and build up some crazy d series, btw no codes either
Old Jun 13, 2004 | 01:02 PM
bossman032's Avatar
Default Re: I give up on b16!!!! (wpgcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic &raquo;</TD></TR><TR><TD CLASS="quote">swap is in my hatch and i get vtec and all but i still cant beat my brothers stock d16a6 in his crx, this is welfare, so i think i am going to sell it and build up some crazy d series, btw no codes either</TD></TR></TABLE>
ur motor is fucked up or u cant drive
vtec cant be beat
Old Jun 13, 2004 | 01:05 PM
wpgcivic's Avatar
i think its the engine cause no matter where we go from, stop, 60 roll into second, he just pulls...fukn doesnt make sense
Old Jun 13, 2004 | 01:07 PM
bossman032's Avatar
Default Re: (wpgcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic &raquo;</TD></TR><TR><TD CLASS="quote">i think its the engine cause no matter where we go from, stop, 60 roll into second, he just pulls...fukn doesnt make sense</TD></TR></TABLE>
maybe ur brother is packing heat it shouldn't pull on a b16a
Old Jun 13, 2004 | 01:12 PM
wpgcivic's Avatar
well its a rebuilt d16 but it is rebuilt to stock specs, i am going to check my timing and then compression...
Old Jun 13, 2004 | 01:13 PM
Rywire's Avatar
Default Re: (bossman032)
For sure man, when I had my b16, I pulled on d16s so hard!! On the highway this crx si pulled up next to me, we hit it at the same time(both down shifted evenly) and before you knew it I was like 10 car lengths ahead of him(in a matter of seconds). Something has to be screwy with your 16.
PS, it was like 2 in the morning, and not a sole on the road. It was a quick thing anyway. Ryan
Old Jun 13, 2004 | 02:05 PM
wpgcivic's Avatar
i sure hope i can figure something out before i decide to sell it
Old Jun 13, 2004 | 02:06 PM
wpgcivic's Avatar
u guys have any other suggestions??
Old Jun 13, 2004 | 02:19 PM
Rywire's Avatar
Check, timing, tps sensor, 02 configuration,codes, reset ecu. How does it run? Hows the driveability? Any idle, bogging issues? Ryan
Old Jun 13, 2004 | 02:46 PM
TIRENECK's Avatar
Default Re: (droppedcrxsi)
U cant drive.
Old Jun 13, 2004 | 02:48 PM
91civicDXdude's Avatar
is the check engine light on?
what ecu are you using?
Old Jun 13, 2004 | 02:53 PM
Synth124's Avatar
Default Re: (91civicDXdude)
Also how crappy is your clutch? Do you have much slip?
Old Jun 13, 2004 | 03:07 PM
Full Race A6's Avatar
Default Re: (Synth124)
My only guess is something with the ecu, your brother is spraying, you cant drive
Do a compression check, timing, check valve lash
Old Jun 13, 2004 | 03:30 PM
spaceman's Avatar
Default Re: (TIRENECK)
lol
Old Jun 13, 2004 | 03:58 PM
atomikpunx's Avatar
how's this pair up in each others cars...
and see how you do in his?
any codes, which ecu?
running 2 o2' sensors wired correctly?
Old Jun 13, 2004 | 04:36 PM
UltimX's Avatar
So how did compression and everything check out?
Old Jun 13, 2004 | 04:44 PM
wpgcivic's Avatar
well i am only running one o2 sensor, no codes, i know how to drive , i just went out to gtech it and fukn ran a 17.17 @ 82, something is wrong with the engine, i am also running a pr3 ecu
Old Jun 13, 2004 | 04:45 PM
wpgcivic's Avatar
my brother is stock si, no slipping clutch either..
Old Jun 13, 2004 | 04:54 PM
Maybe the internals were messed with, compression check, costs $15 at any local place and theyll give you the numbers if you dont know how or have the tool
Old Jun 13, 2004 | 04:57 PM
USDMMARK's Avatar
doesnt the b16 use two one wire o2's?
Old Jun 13, 2004 | 05:02 PM
Default Re: (ORIGIN[AL])
yup, wouldnt make that 4 second gap though
Old Jun 13, 2004 | 06:06 PM
Boosted Chemist's Avatar
Default Re: (W O T)
which tranny (ls = shitty times)
Change plugs rotor cap wire (this improved my car big time)
Check timing (skiped tooth on belt)
Check compression
Run two o2, or it runs real rich w/o code
Use honda top cleaner to get all that carbon out of the head
Make sure your clutch is not slipping at high rpms
then let u know how u make out
Stock b16a should whip up on a d series even IHE
Old Jun 13, 2004 | 06:21 PM
Rywire's Avatar
Default Re: (Mad Chemist)
Get those 02's wired correctly!! Ryan
Old Jun 14, 2004 | 05:39 AM
wpgcivic's Avatar
i am going to try 2 more things
here are results of compression check
210 190 200 200
its fine
hopefully tonight i can get timing checked and then wire up the second o2, if this doesnt work its gone
Old Jun 14, 2004 | 05:40 AM
wpgcivic's Avatar
but like sadi before that missing o2 wouldnt cause it to be like 3 seconds slower than it should
