ls all motor
Old Jun 13, 2004 | 12:25 PM
96civich22's Avatar
Default ls all motor
ok i'm rebuilding my 94 ls motor, and i'm going to build it for all motor, all i need from you guys is parts to get for it. what type of pistons, cams, rods. everything let me know sites to buy it from, and what kind of work i should do to the motor.
Old Jun 13, 2004 | 12:32 PM
3.504's Avatar
Default Re: ls all motor (96civich22)
http://www.crower.com and http://www.eaglerod.com might want to look at http://www.theoldone.com too those are some good places to look, not to mention HT forums for some used parts like a skunk IM. depends all on what build you want to go with. i'd look at the crower 404's or 405's for the cams cause the 403's are pretty weak. i also like 12:1 or higher on compression. you also might want to look into sleeves and think about what bore size you want. oil squirters aren't a bad idea either since the forged aftermarket rods dont have the oil passages like the stocks do. and endyn's pcv breather set up is pretty cool too.
Old Jun 14, 2004 | 12:34 PM
96civich22's Avatar
ttt
sh!ft
Nov 6, 2009 09:27 AM
yarara0825
Sep 28, 2007 09:51 PM
KMk51188
Aug 1, 2006 04:53 PM
87crxAWDmonsteREX
Jan 4, 2005 11:32 PM
96civich22
Aug 5, 2004 07:10 PM
