Tranny and gearbox Questions
Old Jun 13, 2004 | 07:37 AM
PM-Performance's Avatar
Default Tranny and gearbox Questions
Are all B series gearboxes interchangable? Like will all B series gearboxes fit in the b series tranny casings? Will it matter really it they are cable or hydro?
The reason im askng is becuase my synchros are fucked again and i can get a whole B16a1 cable tranny for like $250 from a friend.I was thinking of just taking it to swap in the gearbox and putting my Stock LSD in it and not even worry much about it .
wil this work?
Old Jun 13, 2004 | 09:22 AM
Default Re: Tranny and gearbox Questions (itr206)
No one knows?
Old Jun 13, 2004 | 11:17 AM
Old Jun 13, 2004 | 06:17 PM
am im assumning knowone here knows this?
Old Jun 13, 2004 | 08:34 PM
MAD ITR 55's Avatar
I think the gearboxes are interchangable,but the ITR LSD will only fit in a ITR tranny.
Old Jun 14, 2004 | 04:06 AM
Default Re: Tranny and gearbox Questions (MAD ITR 55)
which part of the ITR tranny? remember i wanna swap the gear boxes only and put them into my ITR tranny casing.
Old Jun 14, 2004 | 06:19 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">
wil this work?
</TD></TR></TABLE>no.
Old Jun 14, 2004 | 06:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">Are all B series gearboxes interchangable? </TD></TR></TABLE>nope.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">Like will all B series gearboxes fit in the b series tranny casings? </TD></TR></TABLE>nope.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">Will it matter really it they are cable or hydro?</TD></TR></TABLE>yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">The reason im askng is becuase my synchros are fucked again and i can get a whole B16a1 cable tranny for like $250 from a friend.I was thinking of just taking it to swap in the gearbox and putting my Stock LSD in it and not even worry much about it.</TD></TR></TABLE>if you have an ITR tranny that is fucked because of synchros, you probably have more wrong than just the synchros since it has happened more than once (correct?)....
it could be your driving style sucks.
it sould be the shift forks or the interlock piece is worn out and needs to be replaced.
it could be your clutch fluid system needs to be bled or a hydro cylinder needs to be replaced.
Now, of course you can replace your tranny with a cable B16 tranny but you'd need to run the cable-to-hydro conversion kit which costs $$ too, so dont bother.
You can swap your ITR LSD into a 92-93 GSR cable tranny case but why bother, there hard to find so they are $$$$$.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">wil this work?</TD></TR></TABLE>mm, no. unless the B16 tranny is a big spline 1992+ cable or hydro tranny this will NOT work.
synchros are cheap man! fix that ****!
Old Jun 14, 2004 | 06:43 AM
Default Re: Tranny and gearbox Questions (owen_the_soyboy)
im not asking why they broke . i know why they broke.
My question is will the B16a1 cable tranny gearbox fit in the ITR housing. Synchros are $211 a piece from Honda. and i dont know yet that that is my whole problem . I know for a fact i now need a new bearing becuasew Honda punched it in with a damn screwdriver and my tranny leaks like a syv. thats why the syncro broke.
Old Jun 14, 2004 | 06:49 AM
No worry now, i called the service manager at Honda. they gonna replace the gear box for me again
BoostKiller
Northwest (Sales)
Jun 9, 2009 08:55 PM
Jonovision
Nov 13, 2005 08:52 PM
spun Vtec
12
Sep 2, 2004 09:51 PM
lucky one
Oct 11, 2003 02:53 PM
