90 integra Gs with 95 gsr motor/92 ls transmissions couple questions
Old Jun 12, 2004 | 08:30 PM
Gant's Avatar
Default 90 integra Gs with 95 gsr motor/92 ls transmissions couple questions
my friend has this set up in his car
well his first ls tranmissions blew up a couple months ago at the track, he had no pilot bearing could this be teh cause of it?
well so now he has a 92 LS tranny, but he coudlnt get the pilot bearing to fit. so hes again running no pilot bearing
hes using a 95 gsr flywheel with a 92 ls transmissions he said the pilot bearing wouldnt fit at all? it was a new pilot bearing also, is there anything u guys know that wouldnt make it not fit?
Old Jun 12, 2004 | 08:33 PM
Gant's Avatar
Default Re: 90 integra Gs with 95 gsr motor/92 ls transmissions couple questions (Ba4)
he said the hole on the gsr flywheel was to small for the bearing
arent all B series pilot bearings the same?
also what could happen in the long run with no pilot bearing?
Old Jun 12, 2004 | 08:36 PM
Cjsls's Avatar
u sure u got the right bearing? U have to tap it into the flywheel, it doesn't just "go" right in.
use a large socket and Gently tap it into the hole.
make sure socket is large enough so it hits against the metal part of the bearing.
Modified by Cjsls at 1:17 AM 6/13/2004
Old Jun 12, 2004 | 08:43 PM
JHD_DA's Avatar
my friend was posting this for me. i have a feeling the pilot bearing had everything to do with my tranny blowing. imma pull my tranny out sometime in july and try to get the bearing in. i dont wanna blow up another tranny.
Old Jun 13, 2004 | 10:20 PM
Gant's Avatar
Default Re: 90 integra Gs with 95 gsr motor/92 ls transmissions couple questions (Cjsls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cjsls &raquo;</TD></TR><TR><TD CLASS="quote">u sure u got the right bearing? U have to tap it into the flywheel, it doesn't just "go" right in.
Modified by Cjsls at 1:17 AM 6/13/2004</TD></TR></TABLE>
also could not runing a pilot bearing cause ur tranny to blow?
Old Jun 14, 2004 | 12:53 PM
Cjsls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">arent all B series pilot bearings the same?
also could not runing a pilot bearing cause ur tranny to blow?</TD></TR></TABLE>
yea, as far as i know they are, but like i said maybe he accidently got another bearing from another car. i mean its just a possibility that im throwing out there.
HondaRexBoi
Apr 3, 2007 05:36 PM
black7hatch
Dec 3, 2006 03:47 PM
eye.ha8.u
Jul 30, 2006 04:26 PM
