OT: i need video camera mount
Old Nov 13, 2001 | 08:16 PM
ITR607's Avatar
New User
Default OT: i need video camera mount
im looking for the bar behind the drivers head area for a video camera mount for autox this weekend any info would be great .
Old Nov 13, 2001 | 08:20 PM
getfast's Avatar
Default Re: OT: i need video camera mount (ITR607)
http://www.ioportracing.com/video.htm
They work, I used to use a borrowed one.
As for the bar to hold it, the only one I know of is from Stable Energies as distributed by I/O Port: http://www.ioportracing.com/restraint.htm
Hope that helps,
Jon
[Modified by JonSE-R, 12:22 AM 11/14/2001]
Old Nov 13, 2001 | 08:24 PM
ITR607's Avatar
New User
Default Re: OT: i need video camera mount (JonSE-R)
cool.. mounts but i also need the single bar that goes from both b pillars also ... forgot tomention that like the mounts
Old Nov 13, 2001 | 08:39 PM
ITR607's Avatar
New User
thanks
Old Nov 13, 2001 | 08:47 PM
itrsport.com's Avatar
Here's my custom camera mount. It's been a while since I put I put it together so I don't have any instructions per say but it might give you some ideas. It's all aluminum and very light weight.
Old Nov 13, 2001 | 08:48 PM
Mugen_R's Avatar
New User
if you wanna get a best motoring image... you can try the following...
You know them camera tri-pods? (but you need to have the OEM rear strut bar) adjust the length of the legs on the tri-pod to sit where you want it in the trunk (where the spare tyre sits). For you guys, the tripod would sit on the right side of the trunk and point towards the driver. Strap the tri-pod to the bar with what ever you want to use so it's nice and secure. And with the tri-pod, adjust the height of the viewing position, tighten it and bingo! Not only you get to see an in-board shot of your car but you can see the way you drive an improve on things you think you are doing wrong!
I would post a pic of how we set it up but i can't find a pic of it! hope that helps!
Old Nov 13, 2001 | 08:57 PM
Chris's Avatar
Hope that helps,
Jon
This is all the info you will need....its what I had and reccomend it to all.
Old Nov 13, 2001 | 09:31 PM
Bob#455's Avatar
Default Re: OT: i need video camera mount (Chris)
And I would like to recommend to all the cheap ghetto mount that I made. It works just as good as one of the expensive camera bars, is easily removable, and easy to make. One catch...it will only work with stock seats (or seats with removable headrests). Get a 3' piece of aluminum tubing, drill appropriate holes for the 4 headrest pins, align driver and passenger seats, install headrests w/ bar in place, then go to camera shop and find appropriate camera mount for the bar... Much easier then it sounds. I should be able to take some pics on Friday when it's in use.
Old Nov 13, 2001 | 10:07 PM
xjohnx's Avatar
Default Re: OT: i need video camera mount (Bob#497)
http://hybrid.honda-perf.org/contrib...ountintro.html
nuff said.
Old Nov 13, 2001 | 10:09 PM
NateBM3's Avatar
New User
Default Re: OT: i need video camera mount (itrsport.com)
Josh nice mount!! never knew you had that, looks simple and easy to use! Good work, did not know a buisness major had it in him
nate
Old Nov 13, 2001 | 10:49 PM
Akira-R's Avatar
Default Re: OT: i need video camera mount (NateBM3)
If you are near the bay area, i have one you can buy of me.
akirateggsr@yahoo.com.
Comes with camera mount too. It is the one that fits between the front seatbelt pillars.
--reid
jnguyen27
Aug 17, 2009 07:57 PM
Black R
May 26, 2004 10:56 AM
98ITR#0020
Mar 28, 2004 10:18 PM
workerbee
Oct 7, 2002 07:10 AM
shamun
Jul 13, 2001 02:57 PM
