saw a home system in a van!
it sounded great and im thinking of buying one so i can use it in my house
http://www.crutchfield.com/S-h...earch=
they had it connected from one of these
which is to play video games but i think it works ok
or i might try this one as its cheap and looks bad ***
http://www.circuitcity.com/dis...-8022
the reviiews are great!
or id buy this one with a seperate subwoofer!
http://www.circuitcity.com/det...6&m=0
id try it in my jeep too just for kicks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe »</TD></TR><TR><TD CLASS="quote">noboddy listens to home audio?
if you like it buy it, if not, dont. I'm not sure what you're asking here
</TD></TR></TABLE>if you like it buy it, if not, dont. I'm not sure what you're asking here
hmm, just wanted to know if anyone has heard any of them, i haven't really i guess i need to go to the store and listen, i want crazy bass in my room!
ok heres a question!
if i buy one of these HOW could i string up 2 subwoofers and a amp to play bass? could i get rca signal from one of these units and hook up my amp via convertor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe »</TD></TR><TR><TD CLASS="quote">if i buy one of these HOW could i string up 2 subwoofers and a amp to play bass? could i get rca signal from one of these units and hook up my amp via convertor?
well if you're talking about using this in your car then just use the headunit to play the cds. Split the RCA's going to the amp and have one set go to the aux in on the minisystem and 1 set to your amp.
now i have a question for you. are you actually going to do this? and is this in adition to the 18" party sub you're thinking about getting?
</TD></TR></TABLE>well if you're talking about using this in your car then just use the headunit to play the cds. Split the RCA's going to the amp and have one set go to the aux in on the minisystem and 1 set to your amp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI »</TD></TR><TR><TD CLASS="quote">
now i have a question for you. are you actually going to do this? and is this in adition to the 18" party sub you're thinking about getting?</TD></TR></TABLE>
this is for my HOME i want to know if i can hook up some subs to the shelf system in my room
the party subs were an idea but advice on other sites say "NO"
i'd only buy this for my room i MIGHT just try it in my jeep JUST for kicks
if its for your house jsut buy one of those little home theater in a box systems. at least taht way you can change out the sub or the speakers whenever you want. They pretty much all have sub output connections.
</TD></TR></TABLE>if its for your house jsut buy one of those little home theater in a box systems. at least taht way you can change out the sub or the speakers whenever you want. They pretty much all have sub output connections.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T »</TD></TR><TR><TD CLASS="quote">Always wanted to hookup my spare Kicked L7 in my room, have a shitty no name 1600 watt amp to power it</TD></TR></TABLE>
you have a spre kicker l7?
i wish i was you
i don't even have a spare
tyre
i wish i was you
tyre
i wish i was you
tyre
- LOL -
I think investing the money and then finding out your inverter can't power your new "system" will definetly make you unhappy - but hey - who knows.
i wish i was you
tyre
</TD></TR></TABLE>- LOL -
this has jsut given me an idea. I've got a spare channel on my CAV-180 so all i need to do is get a sub and build a box and i'm good to go. its 720W @ 2 ohms and i think its 1ohm stable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o_Rage_o »</TD></TR><TR><TD CLASS="quote">
- LOL -
why wouldnt the power inverter not power my new 'system'
which would consist of a shelf system that would just be plugged in, and a bass amp and sub(s)
- LOL -
from my limited expirence - not hearing shelf systems in cars - power inverters are usually meant to provide enough wattage to be able to satisfy the demands of a laptop - small tv etc. etc, i would think that running a shelf system, and then trying to pump it would be overwhelming.
-rage
-rage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o_Rage_o »</TD></TR><TR><TD CLASS="quote">from my limited expirence - not hearing shelf systems in cars - power inverters are usually meant to provide enough wattage to be able to satisfy the demands of a laptop - small tv etc. etc, i would think that running a shelf system, and then trying to pump it would be overwhelming.
-rage</TD></TR></TABLE>
i thought you were talking about running my syatem in my home, that kind of inverter
