My swap, Wiring Help Needed Pics Included
Old Jun 12, 2004 | 02:44 PM
markpa2's Avatar
Default My swap, Wiring Help Needed Pics Included
Hey guys Im stuck on the wiring, I took the dx engine harness off , just cause theres a guy coming tomorrow to pick the motor up, and ive been thinking real hard and searching the net whether i have to take the harness off the b16Its uncut all the plugs are there and it looks like its pretty much the same, cant i just use it, leave it on? It seems to me that it be a wasit to take it off since i still have toi do a MPFI swap? All the plugs plug in except one, its the rectengualr one on the left hand side of the motor that doesnt plug into anything on the b16 harness, in return theres one left on the b16 that is alos on the left side and doesnt plug into anything....Im really confused...lol To those to plugs run the same things
heres a couple pics of what i mean.
dX harness left side plugs
B16 left side plugs, the big circle one plugs in, but the other two dont.
Any help u can give me is greatly appreciated.
Old Jun 12, 2004 | 04:32 PM
DohcVtecCrx's Avatar
Default Re: My swap, Wiring Help Needed Pics Included (markpa2)
OK if you have dpfi in a dx you have to keep that harness and switch it over to mpfi. You cannot use a mpfi harness in a dx engine bay because it will not plug into the car (underdash, ecu) harness. Then there is the issue of the b16a harness being completely backwards because it is for a jdm RHD car which has the ecu on the other side.
So in short take the dx engine harness off the dx motor and swap it onto the b16 then after you swap it in do the dx to mpfi swap per internet instructions. Only other way to make it work is get a full si mpfi ehgine harness and underdash harness.
Old Jun 12, 2004 | 04:54 PM
markpa2's Avatar
K, SO THE B16 harness has to come off and the dx go in its place. will everyhting plug right in?
Old Jun 12, 2004 | 05:59 PM
T-Mo's Avatar
You have to wire it up. Search for "MPFI" in the recent and archives. It is simple to do but, not as simple as you think. You will need to add a few wires and change a few around.
Old Jun 12, 2004 | 06:04 PM
Garrett's Avatar
Default Re: (T-Mo)
You really need help
For MPFI conversion
http://www.fourthgenhatch.com/mpfi.html
Old Jun 12, 2004 | 06:25 PM
ek_99_SiR's Avatar
Default Re: (Garrett)
http://www.thezcr.com
http://www.dmoore.com./crx
Corksil
Feb 7, 2011 07:59 PM
crxrider07
May 29, 2008 11:56 AM
x707saelee88
Jul 16, 2007 07:32 AM
Du_Ma
Mar 16, 2004 09:11 AM
GripFactoR
Nov 21, 2003 02:36 PM
