Sway Bars for 5th GEN
Old Nov 13, 2001 | 07:10 PM
HuGEN's Avatar
Default Sway Bars for 5th GEN
Hey guys, i want to get some sway bars but i don't where to get them cheap. I was thinking of getting the Suspension Techniques but does anybody suggest something else. Please help. Should I get just the rear or both? Thanks guys
Old Nov 13, 2001 | 07:16 PM
Honda318dx's Avatar
Default Re: Sway Bars for 5th GEN (LudeRacer)
Just get the rear swaybar, ST is fine and a great price, it will be one of the best mods you will do!
Old Nov 13, 2001 | 07:46 PM
JinMTVT's Avatar
New User
Default Re: Sway Bars for 5th GEN (Honda318dx)
If u aren't planning on full custom setup and want performance for race drivving..get only the rear ST bar..
if u plan on custom spring rates and suspension tunning get both front and rear..and play with the spring rates to get a good neutral balance..
i got only the rear bar..and it really helps the car rotate..i can do oversteer and understeer on demand now
and i like it
ST are top notch quality and really cheap!
Old Nov 13, 2001 | 08:09 PM
HuGEN's Avatar
Default Re: Sway Bars for 5th GEN (JinMTVT)
Is there a place online that sells it cheap? And how much does it cost. Thanks guys
Old Nov 14, 2001 | 09:51 AM
ShowSpeed's Avatar
i bought a set of Neuspeed front/rear sway bar a long time ago. i believe it's 28mm? not sure.
but Neuspeed makes one tho. go check it out.
Old Nov 14, 2001 | 01:09 PM
John's Avatar
New User
Default Re: Sway Bars for 5th GEN (ShowSpeed)
i believe the front is the same size as OEM, just solid instead of hollow (at least that's what ST specs were)
Old Nov 14, 2001 | 02:55 PM
mickeylude's Avatar
get the rear one, you will love it , DC also makes it, and that is what i have on mine.
wAnNaBe4VTEC
Nov 6, 2004 10:55 AM
Chompn57
Apr 14, 2004 10:34 AM
superturboprelude
Dec 22, 2003 05:51 AM
bad-monkey
Jun 7, 2003 12:47 PM
ActiveAero
Nov 1, 2001 06:27 AM
