ZC, Code 17, now temp / fuel guages going crazy
Old Jun 12, 2004 | 05:25 AM
OneZero1010101's Avatar
Default ZC, Code 17, now temp / fuel guages going crazy
Ok, first my dash lights dont work, so im trying to mess with relays and such. Now, yesterday was just driving and engine light came on, code 17. Think that code is the speed sensor or something like that. Reset the ecu now the code isn't coming on anymore, BUT my gas guage and temp gauge is going up / down not reporting correct readings. Any suggestions gladly accepted, if I might of knocked a wireloose on the relay or something.
Old Jun 12, 2004 | 10:51 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
thats weird cause i have the same code but i dont have a vss yet cause i did the gsr gauges. i would check all ur wires and make ur there all connected.
Old Jun 12, 2004 | 11:39 AM
96-EJ6 B18C's Avatar
Default Re: ZC, Code 17, now temp / fuel guages going crazy (OneZero1010101)
Up for more info...mine does the same thing...tach jumps, fuel gauge reads incorrectly, temp gauge reads incorrectly.
I think in my situation I may have fried some stuff...it started doing it after the intake grounded the postive battery terminal.
Old Jun 14, 2004 | 07:43 AM
hndagirl's Avatar
Default Re: ZC, Code 17, now temp / fuel guages going crazy (96-EJ6 B18C)
hey me too...my speedo doesnt work...my tach doesnst work...or my temp...the only thing that works is the gas gague..thank god....
Old Jun 14, 2004 | 07:58 AM
crx_88_si's Avatar
check the back of the cluster for shorts / loose wires.
twiztid_989
Mar 26, 2009 12:29 AM
Steemo
May 14, 2005 12:01 PM
ucacrx
Jan 1, 2003 08:24 AM
Rob!
Dec 17, 2002 06:34 PM
Pcart
Oct 17, 2002 05:59 AM
