Clutch problem?
Old Jun 12, 2004 | 04:57 AM
onephatcivic's Avatar
Default Clutch problem?
When I start out in first gear my car vibrates and "bounces" at 2000RPM thern is fine. Whats the deal?
Old Jun 12, 2004 | 05:01 AM
pb16b's Avatar
Default Re: Clutch problem? (onephatcivic)
glazed flywheel
Old Jun 12, 2004 | 05:13 AM
Deemeetree's Avatar
Electrician
Are you letting go of the clutch slowly while you rev slowly? Sometimes I catch myself doing that so I won't rev to high and waste gas (). Sometimes it vibrates and the whole front end shakes also.
Old Jun 12, 2004 | 02:14 PM
93Civac's Avatar
yep sounds like glazed fly wheel.
Old Jun 13, 2004 | 07:18 AM
Default Re: (93Civac)
someone said it maybe one of the springs in the clutch? What do you guys think of that?
Old Jun 16, 2004 | 08:46 PM
Default Re: (onephatcivic)
Well you guys were right! Heat cracked and glazed flywheel plus a loose spring in the clutch plate. I just bought a new Fidanza 7.5 lb. flywheel to replace the stock one. Hopefully it works out OK.
Old Jun 16, 2004 | 08:50 PM
Deemeetree's Avatar
Electrician
Hate to hijack the thread, but if your flywheel becomes galzed, can you resurface it?
Old Jun 17, 2004 | 03:55 AM
Default Re: (Dimi)
yes you can. In my case though it was heat cracked pretty bad. PLus if i was going to spend the money to have it machined I figured mite as well go buy a new one.
bank2me
Jun 5, 2011 02:13 PM
Lauj87
Sep 17, 2005 06:32 PM
gsf4726
Jan 15, 2004 10:00 AM
BigBadBuford
Oct 22, 2003 08:34 AM
