HP gain from no AC and no PowerSteering
Old Nov 13, 2001 | 06:24 PM
jond's Avatar
Default HP gain from no AC and no PowerSteering
I know I've seen this here before, but I searched without luck..
Around how much wheel horsepower is gained from disconecting the AC and powersteering?
thanks
Old Nov 13, 2001 | 06:33 PM
BoM's Avatar
BoM
Default Re: HP gain from no AC and no PowerSteering (jond)
search, "power steering" in both recent and archived topics
it'll pop up 30 topics on it.
my AC belt broke before, soo i pulled it out the engine, didn't notice anything.
but then i decided to take the PS belt off too, and notice a nice improvement in hp
i felt faster throughout the powerband, which in theory what u should be.
Old Nov 13, 2001 | 07:01 PM
Big Phat R's Avatar
Not sure about the A/C - it's probably variable depending on whether or not the A/C is on. Maybe up to 10 whp?
Removal of the p/s should net about 5-8 whp conservatively speaking.
Old Nov 13, 2001 | 07:03 PM
Chris's Avatar
Default Re: HP gain from no AC and no PowerSteering (Big Phat R)
AC....none if its not on. PS....3-4 WHP at most.
Old Nov 13, 2001 | 07:11 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: HP gain from no AC and no PowerSteering (Chris)
do a search
A/C: maybe .5hp. Just turn the A/C off, who cares about .5hp?
PS: 3whp/2lbs tq across the board on my gs-r, kenji got 6whp by removing his.
Old Nov 13, 2001 | 08:25 PM
B2FiNiTY's Avatar
Default Re: HP gain from no AC and no PowerSteering (Dave-ROR)
Is that just the belt or the whole P/S system?
Old Nov 13, 2001 | 09:08 PM
Chris's Avatar
Default Re: HP gain from no AC and no PowerSteering (B2FiNiTY)
Just the belt....you wont see ant HP gain from removing weight.
Old Nov 13, 2001 | 09:09 PM
Backmarker's Avatar
On the dyno, I have seen the following gains by pulling the PS belt -
1-2 SAE whp on a gsr
3-4 SAE whp on a b18c5
Folks, please don't guess - share facts!
Old Nov 13, 2001 | 09:13 PM
b00st-0wnz's Avatar
Default Re: HP gain from no AC and no PowerSteering (ITR_Hybrid)
I did. The SAE numbers I've seen are higher than the ones you posted.
Old Nov 14, 2001 | 01:51 AM
Back in Black's Avatar
Rather OG
The largest benefit you'll gain from removing the A/C system is weight loss. As far as power gain, just leave the A/C off...
I personally like the "feel" of my R without power steering. The dynojet ITR-NC generally visits dictated that I gained approximately 4 whp when the belt was removed, which is right on par with James
[Modified by Darth VadeR, 5:52 AM 11/14/2001]
Old Nov 14, 2001 | 03:16 AM
JohnnyBoy's Avatar
Default Re: HP gain from no AC and no PowerSteering (Darth VadeR)
PS belt on my R was worth 4.5 HP
Old Nov 14, 2001 | 07:32 AM
Mike K's Avatar
Default Re: HP gain from no AC and no PowerSteering (JohnnyBoy)
Just an interesting tid-bit of info... we dyno'd my friend's car with the A/C on.
It's a GSR motor with B16A pistons and CTR cams, stock header.
Made high 170s/low 120s at the wheels...
Turned the A/C on one click in circulate mode and it lost about 20hp and 15 ft/lbs of torque. It was crazy!
FYI, the ECU automatically shuts off the compressor at 7600rpm to prevent damage to the clutch assembly. Therefore, peak power at 8000rpm was the same on this run. Just a crazy jump in power at like 7800 or so. Heh..
Old Nov 14, 2001 | 07:37 AM
sackdz's Avatar
Default Re: HP gain from no AC and no PowerSteering (Mike K)
Interesting info indeed..... you got mail
Old Nov 14, 2001 | 02:16 PM
JohnnyBoy's Avatar
Default Re: HP gain from no AC and no PowerSteering (sackdz)
Yeah the same happened to a guy with a Type R . Lost around 15HP but the bypass kicked in and peak power was the same. there was a spike but can't remember at what rpm.
Old Nov 14, 2001 | 02:25 PM
Cosworth's Avatar
facts: my bone stock dyno w/ and w/o AC on (plus headlights, hazard light + defroster):
biglurktm
Jun 16, 2010 07:04 AM
TwistedSI
Feb 21, 2004 06:36 PM
Spartanic
Mar 29, 2002 08:19 PM
B19CivicHB
Dec 24, 2001 02:51 PM
