bad spark on car? help!!
hey guys whats up...i was driving home today minding my own business on the free way going about a cool speed cuz my car was ****** up all day...bogging REALLY badly soundin like a turbo subaru haha it was tight for a time..and then all of a sudden it died out on me on the freeway..it just shut off and i couldnt start it back until like 30 mins later..it just kept on krankin and crankin..i dont even kno what is wrong with it..got home and it jusat died in my drive way..what do you think this might be the cause of this..im guess bad spark? what would cause that?? i recently just got a new timin belt..new water pump..new starter new alt..new dizzy new cap new rotor..new fuel filter...what might be the problem causein this to happen? just to die out and bog super bad
nope...not at all..you kno what else i noticed...it just dies out of the blue all of a sudden when im driving i pull over and then i try and try and try to start it and it finally does...what else to you think it is?
check your timing belt, same thing happened with my car after installing a new timing belt- i just didnt mind to check the timing belt tensioner at all so it skipped a tooth and thats that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shiftquick »</TD></TR><TR><TD CLASS="quote">check your timing belt, same thing happened with my car after installing a new timing belt- i just didnt mind to check the timing belt tensioner at all so it skipped a tooth and thats that. </TD></TR></TABLE>
already check that it was off by 2 teeths and now its on perfect....only thing im guessin is..its still off because my dizzy is all the way advanced right now making it run perfect with the timing belt it shows it perfect timing not advanced at all..a friend of my said it might be my tps sensor or my map sensor thats makin my car just die out..it is a old a6 manifold off a 88..im already swaping it out and puttin a y8 so hopfullie that will stop the problem i have..
