WTB (or would like to use) OBD1 GSR Distributor
<FONT SIZE="3">DONT NEED IT ANYMORE FIXED THE CAR BUT THANKS TO EVERYONE THAT HELPED ME OUT!
</FONT>
Modified by Luserkid at 8:41 PM 6/15/2004
</FONT>Modified by Luserkid at 8:41 PM 6/15/2004
I have the distributor out of my 92 GSR. No rotor button or cap.
Pics http://www.imagestation.com/al...38977
If you are running an external coil I do have an Accord cap that I used for a week.
110.00 shipped in the lower 48 5.00 extra if you want the cap.
Why dont you take off your distributor and check the coil for resistance.. With an Ohm meter. Then take your ignition module to Autozone where they will check it for free??? They can even check your coil if you dont have an Ohm meter. The last test for a distributor is the bearing which you can actually hear go out..Just my 2cents
because the problem isnt the ignitor. And something is seriously wrong with mine, so i would like to see if changing dizzy's would help (thats why i need someone local so i could know for sure)
