adjusting my comptech
I have a DB8 with H&R cup kit and the Comptech sway/tie bar combo. When I installed the bar I set it to medium (recommended By Comptech) and found the car to be more neutral with a hint of oversteer. I feel the car still understeers in certain situations so i am considering setting the bar to hard. By setting it that, what can I expect? Is the car going to roll less? Will it turn in easier? Harsher? does the rear get stiffer during turns?
There is VERY little difference between settings on this bar. It's doubtful that you'll notice a difference at all, unless you have considerable seat time in your car at the limit.
irev210
May 5, 2004 08:17 PM
