HOW TO FIT 5th GEN REAL JDM SiR HEADLIGHTS
A little bit of cutting everything to include: bumper, fender, hood and maybe grill, not really sure. But yes, a lot of custom cutting. Best thing to do is make a 3-d template out of tape or something the exact shape of the light, line it up on the car, trace some cutting marks and start chopping. I would go to a body shop myself.
Uh, I don't know if you're trying to throw this guy off or if you're serious but in any case you're way off
You don't need to have anything done to it. As long as you can splice wires and handle a wrench it'll take you an hour. You have to remove the bumper cover and bumper. Your original USDM lights have a bracket piece mounted behind the actual lights. Take this bracket out (after removing the lights of course) completely and lose it (you won't need it). Your JDMs should bolt up to the same place the bracket bolted up. Then just connect the splices. The hardest part is getting your usdms out because of that killer bolt right under the light but the JDMs don't have that so they go in real easily. DON'T take it to a shop!!!! They'll take lots of your money for something that takes a couple hours at most to do yourself. Let me know if you encounter any problems
so ur sayin that all i need to do is take the actuall headlights off the mounting brackets and jus bolt the JDM ones onto the USDM mounting bracket?????? if that is so, i will be purchasing soon
are they direct??? ive read on accordingly done back a while and some guy had a hard *** time fitting them in properly without some minor shaving here n there...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMAccord2nr »</TD></TR><TR><TD CLASS="quote">No man, they're direct bolt in. And my set came with PIAAs and the light output is about twice that of my old USDMs.
if you would have invested the same amount of money into hid's and a set of retrofit projectors, light output would be about 10X that of the jdm's....
</TD></TR></TABLE>if you would have invested the same amount of money into hid's and a set of retrofit projectors, light output would be about 10X that of the jdm's....
They drop right in , these are the 2 piece headlights that you are talking about ? I presume that they are, drop them and go.... I have CF headlights on my CD, The only modification was to cut into the fender a little, the corner lamp is a bit wider but that was all.
check them out below:
http://www.we-todd-did-racing....D.jpg
i thank all for the input
, ill let eveyone know how they come out when i get em'
but the question is now, WHO HAS SOME THAT THEY WILL SELL ME???????? for not too much that is.
Modified by AVcTcEoCrd at 9:57 PM 6/12/2004
but the question is now, WHO HAS SOME THAT THEY WILL SELL ME???????? for not too much that is.Modified by AVcTcEoCrd at 9:57 PM 6/12/2004
did he not just say the sir headlights? the sir ones are one piece (which are in the shape of the 6th gen usdm accord). those need lots of cutting to make fit. if you're talking about two piece 5th gen with the corners then all you need to do is cut the headlight bracket on top and bottom so that the corner fits.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H »</TD></TR><TR><TD CLASS="quote">there were 5th gen and 6th gen si-r's...the 6th gens need cutting, the 5th gen's do not...</TD></TR></TABLE>
exactly....just the way they are held into place needs to be toyed with a bit
From Japan:
as you can see, theyre the exact same size/shape.....and god, i love those SiR fogs and those dooe visors.....
From Japan:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s.cali alan »</TD></TR><TR><TD CLASS="quote">did he not just say the sir headlights? the sir ones are one piece (which are in the shape of the 6th gen usdm accord). those need lots of cutting to make fit. if you're talking about two piece 5th gen with the corners then all you need to do is cut the headlight bracket on top and bottom so that the corner fits.</TD></TR></TABLE>
For the record, i am talking about the 2 piece Stanley ones from Japan.
exactly which brackets are you talkin about to be cut
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVcTcEoCrd »</TD></TR><TR><TD CLASS="quote">I need to know exactly what to do to get the REAL JDM SiR Accord Headlights to fit right.. Please help</TD></TR></TABLE>
0K f1RsT j00 n33d 2 g3t t3h v-t4k. Th3n m4d tyt3 b0dy k1t y0000!
Actually...I have no idea how to fit them on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAmCman »</TD></TR><TR><TD CLASS="quote">
Actually...I have no idea how to fit them on.</TD></TR></TABLE>
now youve taken it too far....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi »</TD></TR><TR><TD CLASS="quote">
shut up bitch i know you laughed
</TD></TR></TABLE>shut up bitch i know you laughed
