what mount kit did you use? how low does your motor hang?
hey everybody i was looking for pictures of ef swaps to see how low the motor sits with a b-series engine inside the bay...can you all post pics of how low your motor sits (oil pan to ground), what mount kit you have and how much your car is lowered? all help would be very appreciated
well i tried to take a pic of under the car in my garage but that didnt work to well (dark as **** and pouring down rain out now)...i can tell you my crossmember sits a lot lower than my oil pan
b18b1
place racing mounts
H&R true coilovers with no gap
hope that helps
b18b1
place racing mounts
hope that helps
i have the HCP mount kit and my motor sits so low that even at almost stock height my trans hits the ground on some bumps (and no its not because of my suspension) oh and you should see what my jdm integra 4-1 looks like
will be getting hasport soon
i use hasport cabel to hydro kit and i also have a 4-1 header and have not hit it once. i used to have a problem with my last header until i got some real suspension. and now i have not hit it once. and i go down some fucked up roads pretty fast
custom mounts from swap shop here in so cal. my car when it was lowered 2inches would once in a great while scrape the tranny a tincy bit.. when i got the 4-1 header..forget it, that thing was scraping crazy. now im stock height and i only tend to scrape on decent size dips..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crex »</TD></TR><TR><TD CLASS="quote">i use hasport cabel to hydro kit and i also have a 4-1 header and have not hit it once. i used to have a problem with my last header until i got some real suspension. and now i have not hit it once. and i go down some fucked up roads pretty fast</TD></TR></TABLE>
Same here, but I'm using Progress springs for an EF with a B-series.
that black hatch looks great...it seems that the hcp's make the motor hang really low, do the hasports really make that much of a difference or do they just put your clearance issues in another place?
keep the replies coming everybody all help is appreciated, pics would be even better!
Sorry, not a digicam owner.
Hasport billet mounts
h&r race springs
tokiko blues 86-89 accord fronts and civic rears
So I sit a lil bit lower than 2.25 in the front, prolly 2.5 is my guesstamation, and i think the rear is 2"
I have a 4 finger clearance under the car, that's with the stock manifold too. On really big speedbumps i'll scrape tranny or oil pan, but not really on the road just driving.
until i took this pic i thought i was level
h&r race springs
if you do not want you motor to hang low, i would go with hasport mounts, i used the AVID mounts, and they make the motor hang LOOOWWWW, it hang 1.5 - 2 inches below the chassis, when my car was dumped 3 inches, my oil pan was about 2-3 inches from the ground, bad bad cheap mounts, and i was trying to buy some inserts and no one will answer my calls or emails
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus »</TD></TR><TR><TD CLASS="quote">if you do not want you motor to hang low, i would go with hasport mounts, i used the AVID mounts, and they make the motor hang LOOOWWWW, it hang 1.5 - 2 inches below the chassis, when my car was dumped 3 inches, my oil pan was about 2-3 inches from the ground, bad bad cheap mounts, and i was trying to buy some inserts and no one will answer my calls or emails</TD></TR></TABLE>
i already have the damn hcp's
it's too late to turn back...but in the mean while at least we have another thread about this damn mount situation.
personally i have the damn hcp's and in a shittier situation than you
b18c + 4-1 header + hcp =
heres the different mounts ive dealt with so far.
hcp- lots of room behind intake manifold, angles the top of the motor more towards the front, axles come kinda close to where the lca bolts to the x-member, b16a's kinda hang low b18's look above. not really any hood clearance issues. and the front motor mount is not necessary. also theres alot of room for error since theres tons of adjustability
hasport- almost the opposite of hcp whereas the motor sits a bit higher, and more room for a turbo
azracemachine- bling bling like the hasports but with fitment in between hcp and hasport. comes with hardware. im thinkin of getting these since they are pretty darned cheap.
HTH
HTH
Just make a skid plate. Low motor = low CG man!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">personally i have the damn hcp's and in a shittier situation than you
HTH</TD></TR></TABLE>
exactly what my damn car looks like man.. stock height??
i have the same kit and i scrap header, well use to (boost yO!) and my oil pan, but i have my crx dumb low
(skunk2 turned all the way down
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">i am only about 2.5" lowered on b+g coilovers. lostmyboost is probably 4 times lower than me, and he wants a B series in a EF , MUAHAHAHAHHA. </TD></TR></TABLE>
an oil pan 2 fingers off the ground is not low enough..
anyone know how to get maxed out skunk2's to get lower?
hahahah
no someone help him fix his timing belt that likes to eat plastic cover on a regular basis...
hahahah
you guys sure you got the lil ninja star thing on the crank pulley.
it should go
crankend
timing belt pulley
ninja star
crank pulley and bolt
and remember that flying wrench story....... dont be that guy hhhhhhahaha
it should go
crankend
timing belt pulley
ninja star
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mad Chemist »</TD></TR><TR><TD CLASS="quote">
)</TD></TR></TABLE>
i haev skunk2 coils also. but i have pre tension on the front springs. my car you can fit about a finger an a half between the fender and the tire. and i have not scraped my header onece.
)</TD></TR></TABLE>i haev skunk2 coils also. but i have pre tension on the front springs. my car you can fit about a finger an a half between the fender and the tire. and i have not scraped my header onece.
BAAAAAAHAHAHAHAHA best believe i want my cake and to eat it too boyeeee!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by degooser »</TD></TR><TR><TD CLASS="quote">
hahahah
no someone help him fix his timing belt that likes to eat plastic cover on a regular basis... </TD></TR></TABLE>
damn right it ain't low enough, lol! MY TIMING BELT REALLY IS ON CRACK!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">you guys sure you got the lil ninja star thing on the crank pulley.
it should go
crankend
timing belt pulley
ninja star
and remember that flying wrench story....... dont be that guy hhhhhhahaha </TD></TR></TABLE>
i will try that...degooser the ase certified tech decided to just tighten the **** out of it...he's a SICK man! lol that "wrench" story is still cracking me up
fobtions, get your *** over here and fix my car...it better be done in an hour, OR ELSE!!! (inside joke)
thanks for all the help everybody keep them replies coming!
hahahah
it should go
crankend
timing belt pulley
ninja star
i have those bling-bling mounts. I am very pleased with them. As far as fitment goes, no front crossmemeber cutting needed (as ive seen with a lot of diff. mounts out there). Great mounts and great looks. I would post a pic, but i never post pics, and its not being hosted.
i haev skunk2 coils also. but i have pre tension on the front springs. my car you can fit about a finger an a half between the fender and the tire. and i have not scraped my header onece. </TD></TR></TABLE>
im tucking my front wheels a tad plus a had a gsr header (10mm lower due to gsr 10mm block being taller)
