Buildup decisions... Need guidance
Old Jun 11, 2004 | 12:22 PM
J.P.'s Avatar
Default Buildup decisions... Need guidance
I recently picked up a D16z6 from a friend (for FREE), but it is in *desperate* need of a complete rebuild. I want to have this ready for turbo and install in my hatch, by this winter. I need some guidance on selection of parts, and possible buildup techniques as this is my first engine build. I want to take my time and do this right the first time. Here's what i have planned so far, and you all are more than welcome to help with comments or suggestions:
Stuff I already have:
-D16z6 Block(needs cleanup BAD!!)
-D16z6 Head(also needs cleanup)
-D16z6 Intake Manifold(needs cleanup)
-Suzuki Vitara Pistons (claimed 8.5:1 comp on D16) Thanks fjt
-Hastings Rings Thanks fjt
-Stock CX exhaust manifold
-CX trans,clutch,flywheel,etc...
Stuff I know I need/want:
-D16y8 Head Gasket
-LS Rods (block notched for clearance)
-Knife-edged crank
-Adaptor for CX manifold-to-turbo
-JRC.com 6" Intercooler
-custom charge, IC piping/exhaust
-BOV
-turbo timer
Ok, i know thats not a lot, but its what i got in mind right now. I need help with suggestions on some stuff like turbo choice, ECU, fuel management, and any other things im overlooking that i will need for the actual buildup of the engine.
Like i said, i want to do this right and take my time and learn, so i want to do the engine buildup first, before i buy any turbo parts. So if you have any comments or suggestions that you feel will help me out, feel free to let me know.
Thanks for the space guys.
-jP
Modified by [256] JP-03 at 4:59 PM 6/11/2004
Old Jul 1, 2004 | 10:41 PM
ImportHatch's Avatar
Default Re: Buildup decisions... Need guidance ([256] JP-03)
Also interested in the vitara pistons. Was thinking about running these in my spare z6 block.
Yager-
Old Jul 2, 2004 | 04:32 AM
J.P.'s Avatar
Default Re: Buildup decisions... Need guidance (ImportHatch)
If you havent already... Talk to fjt. Hes got the pistons and Hasting rings, for 110 shipped. not a bad deal.
Heres the link:
https://honda-tech.com/zerothread?id=904174
Hes a great seller, fast shipping, no problems... check him out.
-jP
Old Jul 2, 2004 | 04:56 AM
Honda Hick's Avatar
I would really look into getting another head. That one is so rusted on the inside that it will be ALOT of work cleaning up all the valves and whatnot. I think you would be better off picking up a used for for like $50. A lot less hassle. You should be good with the block though because you just bore it and it'll clean right up.
SFrogue85
Jul 26, 2004 09:37 PM
