Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
tire size 225/50/15
Old Jun 11, 2004 | 11:43 AM
esponet's Avatar
Default tire size 225/50/15
my plans are to run 225/50/15 front, 205/50/15 rear. but my rims are only 15x6.5 would a 225 fit? its going on a DC2 i'm going to be using this for both road corse and drags.
if anyone has a pic of their car with this set up pls post. i would like to see the difference in diameter between the two sizes. thanks
Old Jun 11, 2004 | 11:46 AM
JoelG's Avatar
Default Re: tire size 225/50/15 (esponet)
you can squeeze a 225 on a 6 1/2" rim no problem. They'll even go on a 6". suboptimal though, and the tire busters will hate you.
Old Jun 11, 2004 | 01:09 PM
RineRacing's Avatar
Hey Ed:
Alan used to run 225/50/15 Hoosiers on his 6.5 Racing Harts. Not the ideal size but it is possible.
Old Jun 11, 2004 | 02:50 PM
Eee Pee's Avatar
Default Re: tire size 225/50/15 (Geratol)
Don't most of the D stock Type Rs run the 225 front/ 205 rear set up?
They do around here...
Old Jun 11, 2004 | 04:19 PM
XrcR6's Avatar
Heya Ed,
Like Jeremy said I had that for a while on the front, actually they were 225-45-15 Hoosier A3S03's. It was a little wider than 205's in the back on the same rims, but the shorter sidewalls would be angled in on the rim like a sno-cone. Not a big issue since the Hoosiers are really stiff. A 50 aspect-ratio on a softer sidewall tire would be able to bulge more and mount easier, but its not ideal for supporting it. Try a 7-7.5 width if you can.
Old Jun 11, 2004 | 06:30 PM
esponet's Avatar
unfortunately i cant find bfg g force, 225/45/15. all i can find is 225/50. the reason i asked if it would fit 6.5 is that i already have the rims. but who knows maybe i'll see if i can get 2 rims for the front. thanks
btw someone recomended 205 fron, 195/55 rear. this might be a good idea, but since i'm 10 min. from the dragstrip i find myself going there alot. and 205 does not cut it for me. i was trying to avoid buying 2 tires just for drags.
to those that know me, well i'm lazy. i don't like swapping tires.
Old Jun 12, 2004 | 11:17 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">would a 225 fit?</TD></TR></TABLE>
For any particular tire (brand and model), you can look up the range of approved rim widths in the specs on the tire manufacturer's website and/or on the Tire Rack website.
Old Jun 12, 2004 | 03:12 PM
Targa250R's Avatar
be professional
I've seen people using 225/50-13s on CRX DX stock-sized 13x5" wheels. As mentioned, it isn't ideal (a much wider wheel such as 8-8.5" is optimal), and they look like balloons, but it can be done.
Old Jun 12, 2004 | 04:13 PM
StreetMod's Avatar
I have run a 225/50/15 Kumho Victoracer on Rota Subzeros, it works.........
Not a great pic, best one I have of them though........
Old Jun 12, 2004 | 09:39 PM
esponet's Avatar
ok thanks, i actually also have rota subs to put them on. now i'm under the impression that these tires are for autox and road corse, but can be used for drags. someone told me they are drag radial. http://www.tirerack.com/tires/...FA+KD
KaliKid
Dec 27, 2014 05:37 PM
xionl1350
Oct 30, 2006 06:59 PM
LiL JoN
15
Jun 25, 2006 06:30 PM
jdmhatch3
Aug 11, 2005 04:50 AM
zither
Jun 22, 2002 08:14 AM
