car throwing IAC code - O2 sensor causing it?
Old Jun 11, 2004 | 11:37 AM
jmac's Avatar
Default car throwing IAC code - O2 sensor causing it?
I have a B18c1 in my CRX and right now it's throwing a code for the IAC (code 14). I had bought a single wire O2 sensor hooked up but it was throwing the car into limp mode i believe (like a rev limmiter at 3500)and and the car was giving codes for the IAC, TPS and O2, so i disconnected the wire to the O2 and and fixed the connection to the TPS and now the car runs but is very hard to drive except when you have your foot to the mat. It only throws a code for the IAC now. Also the IAC is brand new and clean inside so i highly doubt it's that.
My question is do i need to get a 2 wire O2 sensor for my car?
Old Jun 12, 2004 | 10:06 AM
jmac's Avatar
Default Re: car throwing IAC code - O2 sensor causing it? (jmac)
any ideas out there?
Old Jun 12, 2004 | 10:11 AM
RCautoworks's Avatar
Check your wiring, the 02 sensor had nothing to do with the iac.
924drb20
Dec 14, 2010 10:36 AM
vietnameseone
Jan 19, 2009 06:07 PM
importnoodles
Mar 29, 2008 10:20 AM
Mr.Speed
Feb 21, 2006 07:15 PM
iLOVEmyEMone
Dec 29, 2005 02:57 PM
