engine will start but wont rev
Old Jun 11, 2004 | 11:06 AM
101 civic's Avatar
Default engine will start but wont rev???????????
hey, just did a b16a swap into my 89 civic and got it all done in two days. i just got a big problem the engine well start but well not rev over 1500 rpm it starts to gap as if it were thirsty for fuel but its not cause i checked ? does the vaccume line have to do with it or is it the wiring for the ecu. some plz help gotta try the vtec out.
also i heard that the speed senser needs to be pluged in to run the vtec
and one last thing what wires do you have to cut from the ecu to run the engine [/B]
Old Jun 11, 2004 | 11:58 AM
warrick's Avatar
Default Re: engine will start but wont rev??????????? (101 civic)
more information required.
Si or DX?
what ecu?
what wiring changes did you do already?
what distributor?
what changes did you do with the vacuum hoses?
what intake manifold and throttle body are you using?
did you check your throttle cable?
Mryan
Mar 21, 2006 07:12 AM
101 civic
Jun 11, 2004 02:03 PM
