Act clutch wont disengage completely
Got an ACT 4-puck race disk and an extreme presure plate on a d16z6 in a 91 hatch. I have all the play adjusted out of the cable, but it drags with the pedal pushed all the way down. It looks like the release arm on the transmission isn't moving very far. Anybody else run into this problem?
release bearing, u change it? hook it back up right? if arms not moving much when pedal is depressed than your release bearing isn't contacting the pressure plate correctly. is my guess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Majin Vegita »</TD></TR><TR><TD CLASS="quote">release bearing, u change it? hook it back up right? if arms not moving much when pedal is depressed than your release bearing isn't contacting the pressure plate correctly. is my guess.</TD></TR></TABLE>
Yea, the throwout bearing is in there right. If I adjust all the free play out of the cable and crank the adjuster nut down a bit more it will release all the way, but that's not right.
SOHC_Brian
May 23, 2004 05:15 PM
therealciviczc
Apr 8, 2002 06:57 PM
