Help with one Lug Nut
Hey what's up. I noticed my wheel shaking violently at 55mph+ speeds. So I try and tighten my lugs on my right front wheel and it seems that one of the lugs will neither tighten or loosen and come off. what do I need to do to get this bitch off? thanks
its so close, wow. Ive been taking robo-grip to it and its so loose that i can twist it with my fingers and even move it up and down with them... but it still wont come off... any got any more suggestions?
what kinda wheels
may be able to torch it without hurting them......
get and impact and something to pry against it.......may just HAVE to hurt the wheel some (scratch) but prying while turning will work if you pull and turn hard/fast enough
Just make sure that you don't brake the ''splines'' in the hub so that when you go to seat another wheel stud it wheel stay.
I made the mistake of ruining the splines in the hub and had to replace it.
Goodluck bro
Goodluck bro
*update* I've gotten so desperate to get this lug nut off I've started to offer $ to people if they can get it... my hands are way to bruised to try anymore
take the other lugs off so you can seperate the wheel from the hub enough to get a hack saw in there and cut the bolt off thats giving you the troubles and replace it with a new stud and nut, THERE YOU GO FRICKEN EASY- i dont understand why ppl allways have to make things so damned hard........
*update* IT IS OFF! Wow, that took 2hrs of work (pulling,twisting, and swearing with the robogrip) and I had 7 people try it (offerd $10 for the person that got it off) Thanks a lot for the help guys! Greatly appreciated!
98civdx
12
Sep 20, 2009 12:23 AM
