Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
What is this noise??
Old Jun 11, 2004 | 05:39 AM
tunes12's Avatar
Default What is this noise??
I hear it mostly when autocrossing. Tight left handers, only when on the gas. It is from the right front , but its not the right side axle, I already replaced that thinking that was the problem. It is not a clicking noise, its more of a fast repetitive clunking noise. This is from a b16 with type r tranny. RJ. if you feel this is in the wrong forum, feel free to boot it out of here, I juts don't like dealing with all the other idiots from other forums. Any help would be great, I have some events coming up and I'd rather fix the problem at home instead of 4 hours from home at an autocross, without the right tools. Thanks in advance.
Old Jun 11, 2004 | 05:49 AM
.RJ's Avatar
.RJ
Default Re: What is this noise?? (tunes12)
Wheel bearing? Balljoint?
Old Jun 11, 2004 | 05:52 AM
Mr Furball's Avatar
CV joint ?
Old Jun 11, 2004 | 05:57 AM
Littleton's Avatar
Default Re: What is this noise?? (Mr Furball)
Check your bushings.
Old Jun 11, 2004 | 09:08 AM
tunes12's Avatar
Default Re: What is this noise?? (Littleton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Wheel bearing? Balljoint?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Furball &raquo;</TD></TR><TR><TD CLASS="quote">CV joint ? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Littleton &raquo;</TD></TR><TR><TD CLASS="quote">Check your bushings.</TD></TR></TABLE>
The balljoints seems fine, no play on any of them. Since the Entire axle was replaced, its not the CV joint. The bushings are fairly new, and they look good. Also, since it it not a single "clunk" or two when entering a corner, I don't expect it to be the bushings or the balljoint. It sounds EXACTLY like an axle has gone bad, you know, like "click, click, click" except its a "clunk clunk clunk" (very fast) that continues throughout the entire corner. I'm stumped.
Old Jun 11, 2004 | 09:11 AM
MattD@Stoptech's Avatar
Tie-rod end link?
wheel bearing?
Old Jun 11, 2004 | 09:54 AM
smokin rubber's Avatar
san you feel the clunk happen either through the chassis or the steering wheel?
Old Jun 11, 2004 | 10:04 AM
Xian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunes12 &raquo;</TD></TR><TR><TD CLASS="quote"> It is from the right front , but its not the right side axle, I already replaced that thinking that was the problem. </TD></TR></TABLE>
Was the axle new or a remanufactured unit? If it's a reman, then maybe it's bad too...?
Christian, who knows it's a long shot but also knows that in an infinite unverse anything is possible
Old Jun 11, 2004 | 10:20 AM
tunes12's Avatar
Default Re: What is this noise?? (Xian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">Tie-rod end link?
wheel bearing?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokin rubber &raquo;</TD></TR><TR><TD CLASS="quote">san you feel the clunk happen either through the chassis or the steering wheel?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xian &raquo;</TD></TR><TR><TD CLASS="quote">
Christian, who knows it's a long shot but also knows that in an infinite unverse anything is possible </TD></TR></TABLE>
I'm not sure how a tie rod end link can make a noise like this. I cannot feel anything through the chassis. The axle is a reman, but like you said, it's hard to believe a different axle would make the EXACT same noise.
Which brings me to the wheel bearing. Doesn't a wheel bearing usually hum at speed, and wouldn't there be some play if it was worn?
Old Jun 11, 2004 | 10:50 AM
MightyMouseTech's Avatar
Just because you replaced the axle does not mean that could not be the problem. What kind of replacement axle did you get? Is it OEM or a cheaper aftermarket. I have seen quite a few brand new aftermarket axles that were garbage and needed to be replaced.
Also, is there any rust on the inside of the rotor? I have seen this make this kind of noise quite often. You would not believe how much the rotor and suspension flexes during hard cornering.
As for the wheel bearing. You can have quiet wheel bearings with lots of play, you can have REALLY noisy bearings with no play and everything inbetween. There is no set rule.
Old Jun 11, 2004 | 10:32 PM
mr. carpenter's Avatar
Default Re: What is this noise?? (MightyMouseTech)
i have bought a bad remanned axle before so it's a possibility. does the tire show any signs of rubbing?
Old Jun 12, 2004 | 05:05 AM
h22avid's Avatar
Default Re: What is this noise?? (mr. carpenter)
I was going to say ball joint??? It's a crapshoot when it comes to reman axles but it would be odd for the exact same noise/symptoms to occurr between two different axles.... not impossible but odd.
Have you done any suspension work recently? Check, check, and recheck all nuts and bolts. If you have done anything recheck your lca??? A while back when I put my master bushing kit in I ended up with a nasty clunking coming from my rr during hard cornering or uneven pavement (the rest of the time it was fine; no noise) and I was 100% sure that I had checked and torqued everything.... well short version is it turned out to be a slightly loose bolt at the trailing arm that I somehow missed even after checking everything... or so I thought. I torqued it down and no more clunking
Good Luck
Modified by h22avid at 9:39 AM 6/13/2004
Old Jun 12, 2004 | 09:47 AM
GSpeedR's Avatar
Default Re: What is this noise?? (h22avid)
Whenever I get weird noises/vibrations, I immediately check the things I've most recently fixed/replaced. IF that checks out, then look at anything connected to that hub and move outward.
A is 4 PiMp
Sep 29, 2006 07:29 PM
6thgenaccord
Aug 7, 2006 02:49 AM
eg6turb0
May 10, 2005 01:41 PM
lowRIDAH
10
Nov 18, 2004 06:18 AM
blacksunshine
Apr 30, 2003 05:08 PM
