loose trunk lid
When the trunk lid is closed on my Del Sol, I can jiggle it up and down about 1/4" to 3/8". I have seen other Del Sols and when their trunk lid is closed, it is snug. There doesn't appear to be any adjustment. Any ideas? The latch mechanism looks OK and I can't see where anything has been bent. It just looks like the trunk lid is a bit high when it is closed.
Try moving the Latch up or down , Im almost %99 sure there is an adjustment . Also check to see if the rubber stoppers need to be adjusted. If there is NO adjustment you could always take a Rubber malet and "Adjust" the hitch down a bit
Hard to say without seeing the car
Sonia's Driver
Jan 19, 2011 05:37 AM
Yak BallZ
Feb 18, 2006 12:36 PM
