These rims will fit my car???
Old Nov 13, 2001 | 01:24 PM
[DOD]Ak_RaPi$T~'s Avatar
Default These rims will fit my car???
18" x 8 BBS, 5 x 114 bolt pattern, 215/35/18 Yokohoma Racing Tires...
will these fit my car?? like without trimming the body part near the wheels??
plus i got my car lowed down like 2 inch drop... will it be bad on turns? will the wheels skim the body part in turns?? advice plzz....if u know..!!
Old Nov 13, 2001 | 01:32 PM
Greyout's Avatar
Default Re: These rims will fit my car??? (DOD_Incubus)
you'll be fine
[Modified by JDM LUDE, 10:32 PM 11/13/2001]
Old Nov 13, 2001 | 01:55 PM
aklucsarits's Avatar
New User
You gave us all of the measurements except for the wheel offset measurement. And wheel offset is going to be the most critical factor in this case...
Stock offset on a 6.5" wide 97+ factory Prelude wheel is +55mm
For a 7" wide wheel you'll want at least +40mm. But +43 to +50mm is perferable.
For a 7.5" wide wheel you'll want at least +43mm. But +45 to +50mm is perferable.
For a 8" wide wheel, the wheel is so much wider than stock that there is little room for error. Theoretically you'll want at least +48mm. You'll need to stay in a narrow range right around +48. Any more positive offset than that and the tire will rub on the inside of the wheel well or on suspension componets. Any less positive offeset, and the wheels will protrude out from under the fender lip on the outside...
Andrew
[Modified by aklucsarits, 6:22 PM 11/13/2001]
Old Nov 13, 2001 | 06:22 PM
Default Re: These rims will fit my car??? (aklucsarits)
i c.....
so ur saying 18 x 8 and around 47-49mm offset will be fine for my car..??
like..for sure wont rub..? bcoz my car is freakin low.!!!
Old Nov 14, 2001 | 05:09 AM
New User
If your car is really low, 8" wide is going to be too big no matter what offset you have... I've never heard of anyone running 8" wide wheels on a 97+ Prelude to begin with...
Stick with 7" wide and around a +45mm offset to be safe.
Andrew
Old Nov 14, 2001 | 09:36 AM
skyline69's Avatar
New User
From: Craigavon, Co. Armagh, Northern Ireland, Northern Ireland
Try http://www.geocities.com/chrislonghurst/tyre_bible.html and use Chris's Javascript tyre calculator. If you search for 'Brian Cassidy' (me) on the page you can use my original program (which Chris based the Java on) for calcing tyre and wheel overhang sizes (uses the Prelude offsets as default!).
Brian
Old Nov 14, 2001 | 09:43 AM
ShowSpeed's Avatar
hmmm i've had two sets of 18x8 on my 99 prelude before.
18 x 8 +42mm Racing Hart C5
18 x 8 +45mm Blitz Type 03
i havent had any problems with either set. Then again, i'm not as super-low as DOD... his is at 2".. mine's at... 1.25-1.5 inches.
but like aklucsarits had said... 18x8 is way too wide if you want a 2" drop. play it safe.. and run 18x7.5.
18x7.5... 18x8.. practically the same. no one is going to come up to you and goo.. "dangggg... those 8 inches wide huh". knw what i mean?
goood luck
Old Nov 14, 2001 | 04:09 PM
Default Re: These rims will fit my car??? (ShowSpeed)
lol, showspeed, your riete...but the problem is i am getting second hand rims and they are 18 x 8
Old Nov 14, 2001 | 04:18 PM
To be exact, i thin my rims are lowered 1.8 inches....that is to be exact..!!
jdmcivic1
Jun 20, 2007 07:27 PM
importdreamer
Suspension & Brakes
Feb 16, 2005 03:46 PM
electronb16si
Feb 3, 2005 04:09 PM
crex23
Acura TL, RL & ZDX
Aug 8, 2003 06:53 PM
mr_mbuna
Jan 14, 2003 08:28 PM
