clutch master cylinder
Old Nov 13, 2001 | 12:46 PM
safe driver's Avatar
Default clutch master cylinder
i accidentally let all the fuild drain out of the master cylinder and now when i put more fuild in the tank, the clutch pedal can't pump it anymore.. what is happening here?? i hope i don't need to buy a new master cylinder.
Old Nov 14, 2001 | 11:08 AM
T817's Avatar
Default Re: clutch master cylinder (safe driver)
did you bleed it after you put in more fluid?
Old Nov 14, 2001 | 12:02 PM
Default Re: clutch master cylinder (A_red_car)
i tried to but the clutch pedal won't even pump. i'm totally at a lost here.
Old Nov 14, 2001 | 03:23 PM
prelude1897's Avatar
You are going to have to keep pumping your clutch until it stiffins. This usally takes about 30 to 45 min. to do. You have to take off the little bleader thing on your clutch. I think its an 8mm wrench or shocket will take it off. Once its off, put your finger on it and have someone pump your clutch 15-20 times, then let your finger off. The fluid will drain out, so you're going to have to keep putting more in. Keep repeating this until you can't hold your finger on it anymore. When this happens, put the plug back in. Now, you are going to have to loosen and tighten the blot until the pedal gets stiffer and stiffer. Its kinda confusing, but that is about the best way I can explain it. If you come across any problems, e-mail me at romanticpimp@hotmail.com
[Modified by prelude1897, 4:26 PM 11/14/2001]
lil vin
Jun 21, 2014 01:30 PM
PaulMc
May 18, 2014 05:04 PM
Steviebix33
Aug 14, 2011 07:43 PM
Kronn 98SH
Aug 10, 2008 01:52 PM
Paluce
Jun 1, 2007 12:15 PM
