carbing rear tie bar - quick questions
Old Jun 10, 2004 | 06:04 PM
SD_EM1's Avatar
Default carbing rear tie bar - quick questions
i just need a quick answer (and no idiotic remarks, please)
anyway, i picked up a carbing rear lower tie bar for my Si today, but i noticed that it didn't come with any replacement bolts (unlike the skunk2 tie bar, which includes longer LCA bolts). my question is can i use the stock LCA bolts to mount the bar? and will i have any problems (i.e. bolt not being long enough)?
thanks in advance.
Old Jun 10, 2004 | 07:48 PM
SD_EM1's Avatar
Default Re: carbing rear tie bar - quick questions (SD_EM1)
bump for anyone that might know?
Old Jun 10, 2004 | 07:55 PM
sceg's Avatar
my front lower carbing used the existing bolts, not sure about the rear, cant find a pic of it. if its made like the front bar, you should be fine but im not at all sure
Old Jun 10, 2004 | 08:13 PM
da935oul's Avatar
only one way to find out is to try. if it doesnt fit then just bolt things back up and go buy longer bolts.
Old Jun 10, 2004 | 08:49 PM
hayabusa160's Avatar
my jic bar is ver similar to that one you dont need new bolts its not that much thicker its like putting a washer over the nut its not that thick
Old Jun 10, 2004 | 11:01 PM
Charbon Sty's Avatar
Default Re: carbing rear tie bar - quick questions (hayabusa160)
be safe to just go down to your local tool shed, and buy a bolt of the same diameter but about 1.5cm longer(depending on how thick the tie-bar is etc...)
and use some loc-tite etc, somthing to bond it together. my bolts have come loose, mostly because of my 23mm swar bar, but better safe then sorry.
Old Jun 10, 2004 | 11:28 PM
Miracle_Whip's Avatar
They work...I used my stock bolts and they worked fine.
jlowellintegra
Sep 22, 2010 07:18 PM
alec3369
Feb 9, 2008 09:21 AM
Parker.
Suspension & Brakes
Sep 24, 2007 05:46 PM
wlee112
Jul 12, 2007 08:13 AM
Train
May 6, 2004 09:49 PM
