DSS hub problem need help quick.
Old Jun 10, 2004 | 05:32 PM
underpressure02's Avatar
Default DSS hub problem need help quick.
I just picked up a set of dss stage 4 axles with hubs for my 92 civic. I got the new hubs pressed in and the axles in. I go to put on my brake rotor and it will not go on. It goes to where the hub is and then stops b/c it hits the hub. Do you know if you need to run larger rotors with thier hubs?
I have a generic set of croxx drilled rotors sitting here and they fit over the hub but the rotor is bigger so my brake caliper will not bolt on. Does anyone know if the intergra brake calipers will bolt onto a civic spindle or do I need an integra spindle also?
I am trying to get this car done for this saturday. Need help asap.
TIA
Old Jun 11, 2004 | 05:30 AM
Default Re: DSS hub problem need help quick. (underpressure02)
I am going to try and cut the back side of the rotor where it goes over the hub tonight and see if I can cut enough off to make it fit. Anyone else have any other suggestions?
Old Jun 11, 2004 | 05:36 AM
boosted_dc2's Avatar
pm stan, he will kow what to do.
Landon
jared703
Acura TSX
Jun 7, 2010 08:37 AM
lurkin' eg
Dec 19, 2006 05:53 PM
Imprezor
Suspension & Brakes
Apr 10, 2006 02:09 PM
persain488
Sep 28, 2004 04:30 PM
underpressure02
13
Jun 14, 2004 07:51 PM
