A quickie for someone in the know...
Old Jun 10, 2004 | 04:10 PM
mr_valentino20032000's Avatar
Default A quickie for someone in the know...
I wanted to know if this engine package is basically eveything i need for my swap? oh yeah here is the link... http://www.japanstarmotors.com/zcdohc.html and something else weird about that site but i already asked on here, the whole hydro tranny thing. Oh just for info, i have a 91 Si now and everything is stock in the engine (and everything else), but i want to do everything right..no 1/2 assed stuff if i can help it..but then there is the problem that i only have like MAYBE $1000 to spend...its sad yes but i'm a broke ***** and i really want an engine swap..so yeah will it work?
Old Jun 10, 2004 | 04:44 PM
NickFury's Avatar
Default Re: A quickie for someone in the know... (mr_valentino20032000)
well from the list of parts included it almost there.. but i don;t seem to see them mention these:
- axles (and/or 1/2 shaft if needed)
- tranny..it does say hydraulic but didn't listed as it is included (from the pic it show an automatic tranny)
- D-pipe (can't see from the pic)
but for the price they selling for i don't think it a complete swap..it a semi-complete...
but since you want to put the dohc zc into you 91 si...then you can jsut still retain your tranny/axles/ecu/engine harness and almost everything else...it jsut a plug-N-play deal.....
Old Jun 10, 2004 | 05:08 PM
Default Re: A quickie for someone in the know... (NickFury)
Ok..for the tranny..i was gonna bolt up the Si tranny to the engine, so thats covered..i don't know what axels to use but i need them anyways...and the downpipe...well if the stock one fits i'll end up having to put that one on but if i can afford it i'll most likely buy a after market header with a downpipe attached
Old Jun 12, 2004 | 10:53 PM
NickFury's Avatar
just use the same axles you ahve that is from your old motor...same goes for the exhaust manifold and D-pipe..basically if you still have your old motor there and everything is still there..jsut swap them over to the ZC motor. it pretty much interchangeable.
ef_88_hatch
Aug 28, 2006 04:11 PM
Broken Devil
Sep 11, 2004 03:43 PM
mxtriple711
Aug 26, 2004 06:04 PM
Slvr_CRX
16
Oct 2, 2003 10:37 PM
SoCalifTypeR
Oct 28, 2002 06:52 PM
