94-96 accord motor question
Old Jun 10, 2004 | 07:48 AM
The $hop inc.'s Avatar
Default 94-96 accord motor question
I have a 94 accord ex. and motor is blown. I found a 96-97 accord motor. Does anyone know if this will work? is there any additional wires dats needed to be ran? Any suggestions or help greatly appreciated!!
Old Jun 10, 2004 | 07:59 AM
JDM.Accord's Avatar
Default Re: 94-96 accord motor question (TeamSSR)
This is your opportunity to drop in an H22. Bolts right in. If you're replacing your engine anyway, you have to go with the H22. More power, perfect fit, what more could you ask for?
Old Jun 10, 2004 | 08:05 AM
Default Re: 94-96 accord motor question (JDMAccord2nr)
This is for an older person and they are not interested in power.. As long as they can get from point a-b then its coo.
Old Jun 10, 2004 | 08:07 AM
fw190bvi's Avatar
you want a 94-95 motor......96-97 is OBDII, and would require some modifications....
Old Jun 10, 2004 | 08:54 AM
Default Re: 94-96 accord motor question (fw190bvi)
wat kind of mods is needed?? wiring?
Old Jun 10, 2004 | 08:57 AM
fw190bvi's Avatar
i dont know all that much about the conversion, cept that its a kick in the sack.....basically, ur gonna have to replace the exhaust system with one from a 96-97....new ECU (or u can be ghetto and use a harness converter)...if the new engine dont come with one, ull need new dizzy, etc.......its just ALOT more work, cause the 94-95 will drop RIGHT IN w/o doing anything extra
Old Jun 10, 2004 | 09:02 AM
Grodzman's Avatar
or just get an obd2-obd1 conversion...http://www.accordinglydone.com/tech/tech.php?ID=51
Old Jun 11, 2004 | 11:01 AM
hondadude's Avatar
The intake manifolds will be different, the crank angle sensors were added to the 96-97, the distributors are different.
Block and head will be the same. So yes you can dump the 96 into the 94.
Old Jun 12, 2004 | 04:32 PM
Default Re: 94-96 accord motor question (hondadude)
one last question... do i use the 96 ecu and harness too?
Beau Gotti
Jan 6, 2019 09:07 AM
whitediamond642
Mar 19, 2007 10:42 PM
bozos_si
May 22, 2006 08:30 AM
modifyORdie
Oct 29, 2005 04:56 PM
jbonehead85
Aug 10, 2004 01:50 PM
