different years of crx
Old Jun 10, 2004 | 05:12 AM
GS8HFL21's Avatar
Default different years of crx
i am looking to buy a honda crx but i can not decide what year i should buy. i wanna know what the differences between the 1988-1991 Honda CRX Si. if anyone could help me it would be a great help and if u have any links to sites that have information about this topic that would be an even bigger help because i have been looking every where and can not find anything on it.
Old Jun 10, 2004 | 05:15 AM
crx_88_si's Avatar
get a 90-91 CRX Si.
a littel heavier then the earlier (88 being the lightest of the bunch) but they have 4wheel disks, the non-type R style rear lower control arm (came on 88's). the 90-91 SI ecu's are chippable too.
Modified by crx_88_si at 10:11 AM 6/10/2004
Old Jun 10, 2004 | 05:18 AM
GS8HFL21's Avatar
Default Re: (crx_88_si)
is there any difference between the 90-91 si at all
Old Jun 10, 2004 | 05:26 AM
D-ray's Avatar
Default Re: (GS8HFL21)
N what bennfits do u gain from addiing a chip?? how much more power or horses or what does it do???
Old Jun 10, 2004 | 05:44 AM
Hawkze_2.3's Avatar
Default Re: (D-ray)
Maaaaddd hp's, FO REAL! Chips is OG, playa!
Old Jun 10, 2004 | 06:11 AM
crx_88_si's Avatar
Default Re: (Hawkze_56)
I meant for running turbo edit you foolz!!
Old Jun 10, 2004 | 07:15 AM
warrick's Avatar
<3 TE
Old Jun 10, 2004 | 07:19 AM
-KangaRod-'s Avatar
also the taillights on the 90-91's are way nicer looking IMHO, they have like a trim line around the outside of them. The gauge cluster is a different shape on the 88-89's than the 90-91's, but the 90-91 cluster will fit properly with the right visor (the part that surrounds the cluster)
Old Jun 10, 2004 | 07:26 AM
Jonathan_ED3's Avatar
The dashboard layout of all 90/91 Civics/CRX's look loads better (IMHO) than their 88/89 counterparts!
The only thing the 88/89 styles have on the newer cars is the seatbelt setup, and the grooved trim (which I think looks better)
Old Jun 10, 2004 | 07:30 AM
-KangaRod-'s Avatar
Unless you live in Canada, then all the seatbelts are are on the B pillar where they should be.
Old Jun 10, 2004 | 07:32 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
i have a 91 and i liek it alot but i prefer the 88. its the lightest and has the seatlbelts on the pillar. and the only thing i would do is throw on 91 tailights and ur set.
Old Jun 10, 2004 | 07:45 AM
crx_88_si's Avatar
Default Re: (-KangaRod-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- &raquo;</TD></TR><TR><TD CLASS="quote">Unless you live in Canada, then all the seatbelts are are on the B pillar where they should be.</TD></TR></TABLE>
no this applies to Canada and USA models.
88 - All models, B-pillar mounted belts
89 HF - B-pillar mounted belts
89 Si/DX - door mounted
90-91 All models, Door mounted.
Nihilus
Jul 29, 2007 08:38 PM
pushinglikekrazy
Feb 4, 2006 02:38 PM
pushinglikekrazy
Feb 4, 2006 02:27 AM
