98 Civic EX TERRIBLE fuel economy!
Old Jun 10, 2004 | 04:42 AM
prickert's Avatar
Default 98 Civic EX TERRIBLE fuel economy!
I have a 98 Civic EX (auto) and used to get 300-350 miles to the tankful, just depending on city/highway driving. I now (and have for the past year or so) been getting about 200 miles to the tank. I can push it to 235 miles, but that is with a limp fuel-gauge needle. I've put in a new rotor button, plugs, wires and distributor since then, hoping it would help... to no avail. What else could be doing this?
Peace,
Paul
Old Jun 10, 2004 | 04:59 AM
JimmyAtlantis's Avatar
Default Re: 98 Civic EX TERRIBLE fuel economy! (prickert)
try your fuel filter as well and change the main grounds.
Old Jun 10, 2004 | 05:00 AM
igo4bmx's Avatar
i just got 150 to the tank my last fill up
looks like i need to replace my plugs and get rid of this stupid *** greddy blue box
Deemeetree's Avatar
Electrician
How's your timing? I've been getting REALLY shitty mileage also and haven't been able to figure this out. New plugs, wires, fuel filter, and still shitty mileage. Timing is on to factory spec. Since they changed my timing belt I've been having to use at least 89 octane so my motor WON'T ping. My guess the timing belt if off by a tooth.
Old Jun 10, 2004 | 05:06 AM
FizzGiGG's Avatar
Default Re: (Dimi)
Another problem could be a clogged catalytic converter, it does happen eventually.
Try some injector cleaner too.
Old Jun 10, 2004 | 05:07 AM
prickert's Avatar
Default Re: (Dimi)
Not sure how my timing is.... i'm a mechanical moron... i get a guy at work to help with the piddly stuff (like the wires and plugs) I have a fuel filter I bought a while ago, but it looked rough to change out.... draining the whole system etc.
Old Jun 10, 2004 | 05:08 AM
prickert's Avatar
Default Re: (FizzGiGG)
FizzGiGG-
I've done the storebought injector cleaner stuff... no increase... do you mean try the shop 3-way cleaner system?
Old Jun 10, 2004 | 05:09 AM
prickert's Avatar
Default Re: 98 Civic EX TERRIBLE fuel economy! (JRI94)
What are the "main grounds?" Like I said... a mechanical moron!
Deemeetree's Avatar
Electrician
But if the catalytic converter starts to crap out, doesn't the car bog down a lot? Like very horrible driving? My motor doesn't bog down, but just eats gas as if I were a B18C on turbo or something. Still can't fix it. Stock D15B7.
Old Jun 10, 2004 | 05:19 AM
Deemeetree's Avatar
Electrician
Could it be the damned ECU?
Old Jun 10, 2004 | 05:22 AM
Default Re: (prickert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prickert &raquo;</TD></TR><TR><TD CLASS="quote">Not sure how my timing is.... i'm a mechanical moron... i get a guy at work to help with the piddly stuff (like the wires and plugs) I have a fuel filter I bought a while ago, but it looked rough to change out.... draining the whole system etc.</TD></TR></TABLE>
You lose hardly any fuel at all. Like maybe 3 tablespoons and it's an easy job.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prickert &raquo;</TD></TR><TR><TD CLASS="quote">What are the "main grounds?" Like I said... a mechanical moron!</TD></TR></TABLE>
The only going to the negative battery terminal. There is also a black wire from your valve cover to the chassis and from the transmission to the chassis. Go to a custom audio shop and have news w/ connectors made out of 4 gauge speaker wire.
Old Jun 10, 2004 | 07:22 AM
Jdmbsixteen's Avatar
Default Re: (JRI94)
Try running some seafoam.
Alex98
Apr 12, 2019 05:04 PM
Rick1t
Honda Civic (2001 - 2005)
Jun 14, 2016 02:42 PM
sleepyhamsterlx
Jul 3, 2006 07:19 AM
shhh151
Jun 24, 2005 06:43 PM
jizzer671
Jun 2, 2005 12:40 AM
