Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Aftermarket SRR LCA's with comptech sway bar kit - any probs???
Old Jun 9, 2004 | 05:08 PM
XLR8 GS-R's Avatar
Default Aftermarket SRR LCA's with comptech sway bar kit - any probs???
Hello I will make this short and sweet. I did search so dont yell! Are there any problems mounting the comptech sway bar to the SRR arms?
Old Jun 10, 2004 | 05:58 AM
Mike_C's Avatar
Maybe ask in tech?
Old Jun 11, 2004 | 06:18 AM
SpooN Man's Avatar
Default Re: (MichaelJComputer)
0 a simple bolt in affair. The srr lca's have exactly the same mounting locations as stock a lca.
Old Jun 11, 2004 | 07:50 AM
TodaSi's Avatar
Default Re: (SpooN Man)
I have both and it works out great. Only thing is the stock LCA is threaded while the SRR isn't so I bought a nut to go on the bolt and bolted it instead of threading it on.
Added $.50 to the set-up and an extra minute to bolt on, only cause I dropped a nut on the floor and had to stretch to reach it.
HTH
Old Jun 11, 2004 | 01:16 PM
XLR8 GS-R's Avatar
Default Re: (TodaSi)
Thanks HTH-
I suppose I will end up doing the same nut and bolt trick for the added cost of fifty cents... I just hope I don't drop any parts when I'm putting it all together- cause this cat is too cool to pick things up.
Old Jun 11, 2004 | 04:35 PM
toadolson's Avatar
Default Re: (XLR8 GS-R)
Just order my comptech tie/sway bar and doing the lca's later. Thinking of doing a washer on the opposite side of the of the mounting rod. More surface area, but i don't know how the arms are built.
itslogz
Suspension & Brakes
Sep 29, 2009 08:02 PM
xonn
Suspension & Brakes
Nov 12, 2006 06:45 PM
Linh.
Apr 18, 2006 12:45 AM
numotive
Nov 15, 2005 08:44 PM
216.226.142.95:27016
Suspension & Brakes
Jun 21, 2005 01:41 PM
