Need opinion's
Ok, I have an offer to buy a 1989 CRX SI for $1500, the body is in pretty good condition and so the interior. (if i can get some pics I will post them)
The guy says that the car has a ZC swap, with a LSD transmission.
My question is, is there any way to verify if it is a ZC and LSD? Also is the $1500 a good price or should I just keep looking?
Thanks
Thanks
Is it a dual cam ZC or single cam? Regardless if it's a dual cam you can tell by the valve cover or look at the engine code stamped on the block it should say "ZC". As far as the LSD do a burn out and see if you leave two tracks and not just a peg leg one.
