Using copper spark plugs for 00 Accord 2.3L - good or bad?
I want to use copper NGK v power plugs for my Accord I4. Does anyone know if there would be any problem since the OEM plugs are platinum.
my '99 accord came with copper ngk's, and it's all i use. i was pretty sure only the v6 came with platinum plugs in '00. either way, you'll be fine using the copper plugs. you wouldn't even know the difference.
im not sure about the 99's but for 5th gens, if you have the original manual, they recommend NGK's or Denso's, it should be perfectly fine for your vehicle.
metrowerk
Dec 31, 2018 03:59 AM
kventura
Feb 26, 2008 10:11 PM
