Can someone tell me how to mod the K&N filter for the stock airbox?
Old Jun 9, 2004 | 09:25 AM
Skeletor's Avatar
Default Can someone tell me how to mod the K&N filter for the stock airbox?
I did a search but all the links and pics are broken. Also what is the part number again?
Old Jun 9, 2004 | 04:46 PM
Skeletor's Avatar
Bump for an answer.
Old Jun 9, 2004 | 06:25 PM
fso_BamBam's Avatar
New User
Default Re: (Skeletor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skeletor &raquo;</TD></TR><TR><TD CLASS="quote">Bump for an answer.</TD></TR></TABLE>
Part number is E-2427.
You can get it here: http://www.martelbrothers.com/...9&y=5
And remember, this is a direct replacement, you don't have to modify anything.
Old Jun 10, 2004 | 06:38 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (fso_BamBam)
The K&N stock replacement for Integras is junk and WAYYYYY overpriced. It doesn't even fit like stock (no rubber seal at the filter neck to seal the airbox, and no rubber nib on the end for support).
A better fit is the RU-2820. Take a stock filter, cut off the paper element, and snip off the metal frame. Then you should be able to break the epoxy out of the plastic base (the filter neck). Then attach the K&N w/ a hose clamp.
I also suggest breaking the epoxy off the stock filter endcap (the piece w/ the rubber nib on the end), drilling 4 holes, and attaching the endcap to the K&N w/ 4 small screws. Then it will fit 100% like factory. Best of all, it only costs about $30.
Old Jun 10, 2004 | 08:41 AM
Jdm 98spec R's Avatar
Default Re: (PatrickGSR94)
mine is the same.. and fits perfect!!
Old Jun 10, 2004 | 08:54 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
A better fit is the RU-2820.</TD></TR></TABLE>
.....is this the best filter for people using just the stock itr intake elbow for a short ram? I am trying to figure out what filter to put on this thing or if I should get a 3" short ram (AEM) instead.....
Old Jun 10, 2004 | 09:44 AM
uNF$@#!'s Avatar
Default Re: (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
.....is this the best filter for people using just the stock itr intake elbow for a short ram? I am trying to figure out what filter to put on this thing or if I should get a 3" short ram (AEM) instead.....</TD></TR></TABLE>\
yes, this filter will also work like a short ram.
Old Jun 11, 2004 | 10:14 PM
Black R's Avatar
25 Year Member
.....ok, then what's the k&n p/n for those who want a filter to fit a 3" short ram?
Old Jun 13, 2004 | 10:06 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">.....ok, then what's the k&n p/n for those who want a filter to fit a 3" short ram? </TD></TR></TABLE>
well this filter I'm using does have a 3" flange, so it will fit on any 3" intake pipe.
Old Feb 9, 2005 | 08:11 PM
trutuner's Avatar
bump for a great post that i was too lazy to do!
Old Feb 9, 2005 | 08:26 PM
xprohx's Avatar
I think too much
Default Re: (trutuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
So is there a more detailed write up to this? I need to do this since my cai is out.
*edit: Figured it out
Modified by xprohx at 11:16 PM 2/9/2005
Old Feb 10, 2005 | 06:09 AM
JamaicanDM's Avatar
Default Re: (xprohx)
i did the same thing with a another kind of filter
Old Feb 10, 2005 | 07:00 PM
uNF$@#!'s Avatar
Default Re: (JamaicanDM)
i wouldnt suggest this guys. its so not worth the hassle
Old Feb 10, 2005 | 08:24 PM
SPOON 1's Avatar
Default Re: (255.255.255.255)
JUST get a Spoon Air Filter I have one for sale if anyone is intersted comes with the stock airbox and Spoon Sports sticker on the outside for added JDM BLING*
Old Mar 17, 2005 | 07:52 AM
B_CRUZ!'s Avatar
just did this over the weekend. Great low buck mod. Way cheaper than buying the direct drop in filter.
Old Mar 17, 2005 | 08:11 AM
p nut's Avatar
Fitted the RU2820 on my last integra. Great fit and great price. Highly recommended.
Baron55
Jun 13, 2007 03:08 PM
sikc
Dec 7, 2004 07:42 AM
wreckedmyteg
Apr 18, 2004 06:39 PM
daewonder.
Jan 22, 2004 04:35 PM
Tommy_Gunns
Jul 31, 2001 09:33 AM
