Toda B20 Piston kit?
I currently have an EG6 (b16a2), and im lookin to start an all motor porject. I was thinkin of doin b20vtec. Was pissin about on http://www.todaracing.com and found they do a piston kit for a hybrid b20 block=
"2000CC Piston Kit
Our special piston kit is designed to be used with Type-R crankshafts and rods in a B20B block along with a B16A or Type-R cylinder head. The advantage is having a reliable 2.0 liter engine with an optimal rod-stroke ratio allowing for high rpm operation. Requires VTEC converstion kit commonly used on LS-VTEC engines.
Parts Required For Build ..... Up Parts Source
B16A or Type-R Cylinder Head ..... Honda B16A, Integra Type-R, Civic Type-R
B20B Engine Block ..... Honda CRV, Stepwagon, SMX
Type-R Crankshaft ..... B18C Type-R
Type-R Connecting Rods ..... B18C Type-R
B20B Headgasket ..... Honda
VTEC Conversion Oil Line Kit ..... Most Honda specialist carry this product
Piston Size .. Compression Ratio .. Displacement .. Bore x Stroke
85.00mm .... 12.1 : 1 ................. 1979cc .............. 85mm x 87.2mmm"
Anybody done this build or have any experience of it, know where i can get details?
Cheers.
"2000CC Piston Kit
Cheers.
j_wod2000
22
Feb 15, 2006 10:22 AM
