injector question for gsr
Old Jun 9, 2004 | 06:20 AM
Shelton's Avatar
Default injector question for gsr
first... are ls injectors the same as gsr injectors?
Second.. upgrading the injectors on a all motor application what size is safe with a stock head, i hae a fuel pump, rail and fpr, the pistons are upgraded to ctr 12.1 cr, and i have other bolt-ons! thanks for the posts!
Old Jun 9, 2004 | 06:48 AM
4door-r's Avatar
Default Re: injector question for gsr (Shelton)
ls are a smaller cc then gsr. what cams are you using? w/ 12:1 comp. you should have 270cc-310cc.
Old Jun 9, 2004 | 08:08 AM
Phatch99's Avatar
Default Re: injector question for gsr (4door-r)
r u sure they are different? can anyone else verify this? i thought all b-series injectors have the same cc's?
Old Jun 9, 2004 | 08:12 AM
agreziv89ef-8's Avatar
Default Re: injector question for gsr (Phatch99)
i heard all b series injectors are the same.. i was using ls injectors on my b16 in a crx....i had no problems...
Old Jun 9, 2004 | 08:31 AM
4door-r's Avatar
Default Re: injector question for gsr (agreziv89ef-8)
im pretty sure stock B20 injector are bigger then b18 & b16. i might be wrong.
it really doesn't matter cuz he needs big injectors any how.
Old Jun 9, 2004 | 08:45 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door-r &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure stock B20 injector are bigger then b18 & b16. i might be wrong.
it really doesn't matter cuz he needs big injectors any how.</TD></TR></TABLE> you are wrong.
ALL of the civic and integra injectors are the same... 240cc.
the only differences are the clip styles per OBD year/style.
there is the possibility of JDM ITR injectors being larger at around 270cc, I cant remember if that got verified or not.
Old Jun 9, 2004 | 09:19 AM
TEAM562racing's Avatar
i just happen to have a set of RC 310cc's that should work fine for you.
p'm sent
Old Jun 9, 2004 | 08:44 PM
Shelton's Avatar
thansk for all the posts pm's answered!
Old Jun 10, 2004 | 07:43 AM
xtrac1's Avatar
rookn00b
ALL the B-series injectors are rated at 240cc. The top of the line single cam VTEC D-series also use 240cc injectors.
For bolt-ons with increased compression, the factory injectors should be OK. Just use an adjustable fuel pressure regulator to fine tune it.
General manager/RC Engineering
Old Jun 10, 2004 | 07:56 AM
dfoxengr's Avatar
all b and most d are 240cc
dc4b20
Mar 28, 2009 05:02 PM
19integra91
Mar 3, 2009 08:31 PM
jksmith
Apr 19, 2008 09:56 AM
xtegb16x
Mar 3, 2006 09:35 PM
MrEg
Oct 12, 2003 10:39 PM
