wheelie wobble
Old Jun 9, 2004 | 12:25 AM
Usdm1's Avatar
Default wheelie wobble
Everynow and then i get this wobble when its up, so i let it back down. anyone have ideas on what causes this? when it gets higher it wobbles more, not all the time tho. i dont feel like im doing anything diff. like moving my body ect.
oh yea, im running about 20lbs of air.
heres what it looks like clip here
Old Jun 9, 2004 | 06:52 AM
BoostedSi's Avatar
Default Re: wheelie wobble (Usdm1)
hmm, i used to get the same wobble when i was doing sitdowns at around 20mph. It would wobble like crazy if i brought it up too high. How fast are you doing your wheelies? I just stopped doing sitdowns so i dont get those wobbles anymore.
Old Jun 9, 2004 | 09:20 AM
Usdm1's Avatar
Default Re: wheelie wobble (BoostedSi)
im starting at 18-20mph. 1st gear.
what tire pressure were you runnin at?
Old Jun 9, 2004 | 09:21 AM
BoostedSi's Avatar
i was running at 20psi also. Now i run on 25psi and do standups. Try running 15psi
Old Jun 9, 2004 | 02:40 PM
TurboInteg95's Avatar
what speed are you getting these wobbles at? I was reading around on the R1 forum and people say that when you get high up into the RPM band it can start to cause wobble. I have experienced the wobble around 80 mph in 2nd gear standups. Basically they say for high speed wheelies to use 3rd gear but I haven't gotten the ***** to try that yet. This of course is on an R1, but the same thing may apply to other bikes. just a thought
Old Jun 9, 2004 | 02:42 PM
Default Re: wheelie wobble (TurboInteg95)
Nevermind, I just saw your video. looks weird, are you sitting down?
Old Jun 9, 2004 | 04:09 PM
slylos's Avatar
Are you doing sit-downs or stand-ups?
Old Jun 9, 2004 | 04:20 PM
Usdm1's Avatar
Default Re: wheelie wobble (slylos)
this is all sitting down going about 50mph
Old Jun 9, 2004 | 04:44 PM
BoostedSi's Avatar
try to be easier on the throttle. Bring it up high enough where you hardly have to use throttle. Being too jerky on the throttle might be the reason why.
Old Jun 9, 2004 | 06:35 PM
slylos's Avatar
Sit-downs at the balance point going that speed are always a little wobbly, especially right when you first approach the balance point are you at yours BTW? . . . your weight is lower placed on the bike and it doesn't affect the bike as quickly . . . as long as it doesn't get too bad, don't worry about it . . . stand-ups are alot less wobbly, maybe you should try them the road can affect it as well, I tend to be really wobbily on some roads and not so much on other roads . . .
MNDALOVE
Sep 17, 2016 04:15 PM
skaraider
Engine Management and Tuning
21
Jul 6, 2012 03:22 PM
blackeg
11
Oct 5, 2010 06:53 PM
Gator0302
Honda Civic (2006 - 2015)
May 5, 2010 09:26 PM
bbqman
13
Apr 24, 2003 09:48 AM
