91 ef hf cluster question
just recently got a project crx and the original cluster was stolen. there are 3 harneses and a speedo that go into the cluster.
1st question- which harness controls the check eng light, alternator, seat belt.. and so on?
2nd question- when the oringal cluster was stolen, the pretty much ripped out the harnesses quickstyle. the harness on the right (about the speedo plug) 3 wires are torn out of the clip with the pins still suck in the clip, so the wires are bare. how do i fix this.
i need the check eng light to turn on when i put the key into the ON postion for a smog check.
try to get an old harness from a yard and you should be able to colormatch. i had an old diagram from when i did my cluster swap i'll see if i can find it.
http://www.4thgenerationcivic.com/
found this and also a couple of other write ups in archived search for cluster swap in ef forum. hope it helps.
i that link, look under how tos and scroll to the bottom of aftermarket customs.
Modified by mr. carpenter at 5:08 PM 6/9/2004
