Spoon caliper rebuild
Old Jun 8, 2004 | 09:27 PM
JDM Factor's Avatar
Default Spoon caliper rebuild
Anyone know how or where I get the parts to re-build the calipers?
Old Jun 8, 2004 | 09:47 PM
mikehonda's Avatar
Default Re: Spoon caliper rebuild (JDM Factor)
Good luck to yA
You can try to contact Mike M on this board
Old Jun 9, 2004 | 11:46 AM
ZygSpeed's Avatar
Default Re: Spoon caliper rebuild (mikehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikehonda &raquo;</TD></TR><TR><TD CLASS="quote">You can try to contact Mike M on this board</TD></TR></TABLE>
And then post the info here for the rest of us suckers.
Old Jun 9, 2004 | 11:50 AM
BlueR's Avatar
Default Re: Spoon caliper rebuild (zygspeed)
&lt;-----------------------
would like to know also, even tho i don't need one yet
Old Jun 9, 2004 | 11:57 AM
MattD@Stoptech's Avatar
Default Re: Spoon caliper rebuild (BlueR)
I'm pretty sure Wai knows...
Old Jun 9, 2004 | 11:59 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">&lt;----------------------- would like to know also, even tho i don't need one yet</TD></TR></TABLE>
Same here, however I'm about to finally install my 6 month old/used Smurf calipers on the other car but am somewhat hesitant to do so w/o consumables for them in terms of o-rings and whatever's needed to refurbish them.
Maybe these items can be purveyed from another source ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure Wai knows...</TD></TR></TABLE>
Old Jun 9, 2004 | 12:02 PM
REDTOPAlchemy's Avatar
try contacting Opak Racing in CA. They're a major Spoon distrib. in the nor cali. I also heard they have a team of spoon guys at the shop as well.
http://www.opakracing.com/home.htm
Old Jun 9, 2004 | 12:03 PM
ZygSpeed's Avatar
Default Re: Spoon caliper rebuild (PYXITR)
Thank You.
Old Jun 9, 2004 | 03:19 PM
JDM Factor's Avatar
The tech guy at Opak was out of town, so i just left him an e-mail. When I find out the news, I'll post it up.
Old Jun 9, 2004 | 05:27 PM
bryant's Avatar
I remember reading about something they are not rebuildable, but I would like to know also. That would really change some things.
Old Jun 9, 2004 | 08:57 PM
JDM Factor's Avatar
I wonder if I should contact Nissin see what they have to say.
Old Jun 10, 2004 | 12:06 AM
Tsukuba 699's Avatar
Default Re: (JDM Factor)
I know a few guys down in Tokyo, I can see what I can find out as well.
I have been running Spoon Calipers for close to two years and I have not needed to rebuild them.
I am curious to know how you know they have to be rebuilt?
Old Jun 10, 2004 | 05:13 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: Spoon caliper rebuild (El Pollo Diablo)
AFAIK there's no rebuild kit available for the Spoon calipers.
However, after using them for about 4 to 5 years, I still haven't seen the need of rebuilding them yet.
Old Jun 10, 2004 | 05:14 AM
.RJ's Avatar
.RJ
Default Re: Spoon caliper rebuild (Wai)
Couldnt you just measure the seals and see whats already available?
Old Jun 10, 2004 | 05:15 AM
Footwork's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wai &raquo;</TD></TR><TR><TD CLASS="quote">However, after using them for about 4 to 5 years, I still haven't seen the need of rebuilding them yet.</TD></TR></TABLE>
Old Jun 10, 2004 | 05:41 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know how or where I get the parts to re-build the calipers?</TD></TR></TABLE>
rebuild = send me your calipers and I will send you a new set of OEM ITR calipers.
Old Jun 10, 2004 | 06:44 AM
Wai's Avatar
Wai
Default Re: Spoon caliper rebuild (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Couldnt you just measure the seals and see whats already available?</TD></TR></TABLE>
There are no rubber seals around the pistons. Hardk0re race clapper sty0!
But there must be some other rubber seals inside, but can't be seen or measured unless you take the whole thing apart.
Old Jun 10, 2004 | 08:03 AM
Black R's Avatar
25 Year Member
Yup. And EPGONZALEZ has the hookup on all the possible sizes you'd need.....
Old Jun 10, 2004 | 08:08 AM
But there must be some other rubber seals inside, but can't be seen or measured unless you take the whole thing apart.</TD></TR></TABLE>
That doesnt' sound right....there is no dust shield, but there should be a rubber seal in a gr00ve on the piston, between the caliper body and piston itself.
Old Jun 10, 2004 | 08:24 AM
Wai's Avatar
Wai
Got this pic from itrsport.com's thread from a while ago:
When looking at the pistons, there's no rubber boot or seal between the pistons and the caliper body.
Old Jun 10, 2004 | 08:25 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wai &raquo;</TD></TR><TR><TD CLASS="quote">When looking at the pistons, there's no rubber boot or seal between the pistons and the caliper body.</TD></TR></TABLE>
How does it create a fluid seal then?
Old Jun 10, 2004 | 08:37 AM
I don't see what the picture shows....I dunno if we're talking about the same thing.
A stock caliper has two rubber rings on it...the outer one which is the dust b00t and can be seen when chaning pads, and an internal rubber ring, which is the seal, and can't be seen unless the piston is removed out of the caliper. It creates the seal between the caliper body and the caliper piston, so the fluid doesn't leak out.
I don't see how the sp00n calipers do not have rubber/plastic seals.
Old Jun 10, 2004 | 08:39 AM
Wai's Avatar
Wai
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">How does it create a fluid seal then?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wai &raquo;</TD></TR><TR><TD CLASS="quote">But there must be some other rubber seals inside, but can't be seen or measured unless you take the whole thing apart.</TD></TR></TABLE>
Old Jun 10, 2004 | 08:42 AM
Correct Wai...so take those clappers off, get a supply of compressed air...place a stick of w00d in the clapper...and P0000F, out come the pistons
Old Jun 10, 2004 | 09:01 AM
JDM CTR '00's Avatar
I think it has O rings inside.
