Truechoice Suspension Solutions?
Hey is anyone running the phase 2 or phase 3 setup on there car? Just wondering if its a good setup to use. I am currently running a 95 Prelude Si, if anyone has info post it up. Thanks
Oh yeah heres the site http://www.truechoice.com
http://www.imagestation.com/picture/...f/f857fd04.jpg
This is Phase 2 setup
http://www.imagestation.com/picture/...c/f857fd01.jpg
This is the Phase 3 setup
Phase two with Phase three hardware user here.
The only problem with the Truechoice suspension that I have come across is the Eibach springs are 2.25" instead of the very common 2.5".
Notice I said "very common", 2.25" is not so common, but not hard to find.
Doing it again though, I would have chosen Ground Control, simply because of the 2.5" diamter spring.
I have the Phase 3 stuff on my Integra. Lee from Koni sent me some handy-dandy 2.25 to 2.5 perch converters that work just fine. Inexpensive too as I remember (like <$10 each).
Incidentally, anyone using this setup have a lot of noise realted to it?
Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eee Pee »</TD></TR><TR><TD CLASS="quote">Phase two with Phase three hardware user here.
Doing it again though, I would have chosen Ground Control, simply because of the 2.5" diamter spring.</TD></TR></TABLE>
Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerMike »</TD></TR><TR><TD CLASS="quote">
Mike
Have you tracked down the cause of the noise? Is it from the spring rubbing on the coilover sleeve or sliding around on the perch? If it's from the spring rubbing on the sleeve, it's probably due to the spring "bowing" and contacting the sleeve because there's not alot of clearance between the sleeve and the spring.
Mike
Phase 4 user here....
Only issue I had/have is that when they repainted the shocks pimpy blue they got too "fat" to fit in the lower fork on the front. I had to grind off the paint.
2.25" springs aren't a very big deal.
Nash - who loves the DA feature
I've had the Phase 2 for the last three years.
They came with upper mount.
I like the 2.25 myself, they are smaller, and weight a little less. Negative is they don't come in very tall sizes, which most people don't want anyway and they cost a little more (not sure why?). I wish the sleeves were a little longer but not really needed with the multiple perch's on the Koni's.
Noise: haven't had any issues that come with springs that have no rubber between them and the mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpl95si »</TD></TR><TR><TD CLASS="quote">2.25" will give you just a smidge more tire clearance..... right?</TD></TR></TABLE>
The steering knuckle/hub to upper ball joint is what will rub on a double A arm suspension.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerMike »</TD></TR><TR><TD CLASS="quote">Incidentally, anyone using this setup have a lot of noise realted to it?</TD></TR></TABLE>
In the rear I did going around corners on the Autocross until I got a helper spring Then removed them, and the rear bar I installed eliminates droop, and therefore there's no noise. It was the spring unseating, rattling around on the threaded collar, then banging back into its perch. Scary, loud, but fixable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rambler »</TD></TR><TR><TD CLASS="quote">2.25" springs aren't a very big deal.</TD></TR></TABLE>
Back in February I tried to get Eiback 700-800 pound springs. Eibach told Truechoice not until October at the earliest. The demand wasn't high enough. Used is always an option, but I haven't found what I have been looking for. Hypercoils for about $25 more, will get me what I want, if they have them, I haven't called.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22mark »</TD></TR><TR><TD CLASS="quote">Thanks everyone, do the Phase 2 and 3 come with upper mounts?</TD></TR></TABLE>
The upper mount pictured is what the top of the spring fits into. That piece rests in the OEM top hat.
DIRTYsouthBB6
Oct 10, 2007 05:06 AM
nhatquang
Jul 7, 2006 09:10 PM
