sunroof relay?
Old Jun 8, 2004 | 03:40 PM
RIOredKIRKLANDcrx's Avatar
Default sunroof relay?
ok so when i got my crx the guy told me that the sunroof doesnt work because of a bad sunroof relay. i didnt really car since it was winter but now that its summer it would be nice to have my sunroof working. so im asking where is this relay at? and how much is it to replace?
thx in advance
Old Jun 8, 2004 | 04:12 PM
kamikazeCRX's Avatar
Default Re: sunroof relay? (RIOredKIRKLANDcrx)
The sunroof relay is located behind the sunroof switch, to the left of the steering wheel, behind the dash. It's not too hard to get it out. Just follow the wires from the switch to the relay.
Most of the time it's just the connectors on the relay that are tarnished and just need to be polished up for the relay to work, that was the case with my car. I could open the roof, but i had to close it manually because the switch wouldn't do it.
Or you could just get a new one.
Old Jun 8, 2004 | 04:19 PM
Default Re: sunroof relay? (kamikazeCRX)
thx for the info im got check it out right now....if i need i can get the relay at the H dealership right?
Old Jun 8, 2004 | 04:22 PM
Ya they'd definitely have it there, or they can order it in for you. But Honda is a rip off for parts like these. I would check the local wrecker first...then again it might just be worth it to get a new one.
Old Jun 8, 2004 | 04:34 PM
o ok thx for lookin out..ill hit up the junk yard this week
Old Oct 15, 2020 | 01:49 PM
Kid jumper's Avatar
Default Re: sunroof not working properly
Just fixed the sunroof on my Honda eg8 but it can only open not close checked the fuses , replaced them but nothing only opens I can close it manually but open it with a push if a button
Old Oct 15, 2020 | 04:32 PM
Tyson's Avatar
on a CRX its the switch, it needs cleaning. take it apart and clean contacts, put electrical grease on contacts. its almost always the case.
Old Oct 15, 2020 | 11:02 PM
Kid jumper's Avatar
thanks Tyson the switch just need abit of cleaning it works perfectly now thanks so much 👍
Ramona Zavala
Jul 3, 2012 02:12 PM
dalek
Dec 26, 2007 12:21 PM
GS8HFL21
Nov 9, 2005 06:56 AM
xcathodex
Audio / Security / Video
34
Mar 1, 2003 03:42 PM
