welding in b16 mounts??
Old Jun 8, 2004 | 08:27 AM
dub204's Avatar
Default welding in b16 mounts??
i have decided to weld in b16 mounts. the reason for this is that i will be driving my car in the winter, and here in canada, it gets to be -40 degrees celcius. i've used the hasport mounts before and when it gets that cold the mounts will freeze and make the vibrations unbearable. does anyone have experience welding in these mounts? i know i need the teg rear bracket and drivers side mount.
Old Jun 8, 2004 | 08:52 AM
mr. carpenter's Avatar
Default Re: welding in b16 mounts?? (dub204)
would'nt welding make it worse even in warm weather?
Old Jun 8, 2004 | 08:54 AM
dub204's Avatar
Default Re: welding in b16 mounts?? (mr. carpenter)
no becasue i dont beleive i wil be wedling the engine to the car, just relocating the engine brackets so that u can use rubber engine mounts
Old Jun 8, 2004 | 08:55 AM
ah ha
Old Jun 8, 2004 | 10:17 AM
civickiller's Avatar
the ls motor i got, the car it came from, the guy rewelded the chassis engien mounts so he could use the stock rubber mounts
GoLowDrew
Jun 25, 2013 08:34 AM
EG6Boy702
33
Apr 27, 2009 03:55 PM
svacca1
Nov 16, 2007 08:49 PM
td04civic
May 7, 2002 04:56 PM
