CRV Block?
Old Jun 8, 2004 | 04:50 AM
onemanlan's Avatar
Default CRV Block?
I've noticed some people that construct frankenstine engines(or whatever you want to call them) use CRV blocks. May I ask why? It seems a bit weird to me, but I would like to know the advantages of using a CRV block. Thanks.
Old Jun 8, 2004 | 05:11 AM
SMSP's Avatar
Default Re: CRV Block? (onemanlan)
84mm bore
VTEC heads bolt to it
Old Jun 8, 2004 | 05:25 AM
deSigi's Avatar
Default Re: CRV Block? (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">84mm bore
VTEC heads bolt to it</TD></TR></TABLE>
I've been curious about these setups as well. What about the block internals? Would they be able to hold up against high revs from a b16 or b18 vtec head? What about the oil jets? Does the B20 have oil jets? I also heard that the B16A heads bolt-up w/o a problem, but the B18C1-5s don't. Is this true?
Old Jun 8, 2004 | 08:11 AM
dfoxengr's Avatar
Default Re: CRV Block? (e-kay)
search. i am getting really sick of the mickey mouse lsvtec questions since theres like a thousand posts on them already.
Old Jun 8, 2004 | 12:44 PM
93supercoupe's Avatar
Default Re: CRV Block? (hybridvteceg)
thin cylinder walls and i also agree with hybridvteceg
Slammpig
Old Jun 8, 2004 | 12:48 PM
EKCivicR's Avatar
It's all displacement = POWER! 2.0L vs 1.6L? You do the math...
Old Jun 9, 2004 | 07:02 PM
chrisCNL's Avatar
Default Re: (EKCivicR)
I agree with EKCivicR...The displacement 2.0 L stock from the factory.
Old Jun 10, 2004 | 04:41 AM
BLACKekTURBO's Avatar
TORQUE. TOURQUE.. AND MORE TORQUE......
Old Jun 10, 2004 | 05:51 AM
2000ekhatch's Avatar
Default Re: CRV Block? (allmtrctr)
the oil squirters are a give take thing, they add additional rotating mass while cooling the pistons, some scca specific motors ive delt with delete them and instead run a richer mixture and modified rings and lands to cool the piston just as effectively. its either ya want them or you don't.
all b series blocks are pretty much the same after in all of the 90'ish models w/ a few exceptions (no flaming please, its a generalization)
lsvtec225
Feb 28, 2007 03:16 PM
caminSi
12
Sep 7, 2006 03:26 PM
Turbo_y8
Feb 20, 2005 09:09 PM
ace1875
Jun 13, 2003 11:49 PM
98TypeR
Sep 28, 2001 03:24 PM
